Old 10-14-2015, 09:41 AM   #1
SiRed94
Drives: Too Many to List
2ZR-FE Technical Question
I have a 2011 Yaris HB that I am starting a 2ZR-FE swap in. I understand all of the mechanical aspects of the swap. However, my hang up is with the ECU/Immobilizer. My Yaris is equipped with an immobilizer and the ECU that I got from a 2011 Corolla also is immobilized. My question is, can a Yaris VIN be written to a Corolla ECU with TechStream? Can the Yaris key be programmed to the Corolla ECU? If the Yaris VIN is written to the Corolla ECU, will TechStream detect that it is a Yaris VIN and attempt to flash the ECU with Yaris fuel/ignition maps? It seems that most vehicles that 2ZR-FE swaps come from are equipped with an immobilizer, so if someone could shed some light on this, or steer me in the correct direction to another option, I would be very appreciative. I really do not want to retain the factory ECU, even if it can be tuned via piggyback, for lack of dual VVTi control. Thanks in advance.
SiRed94 is offline   Reply With Quote
Old 10-14-2015, 11:27 PM   #2
It is definitely more of a hassle with a 2009 or newer Yaris. You would need the ECM and keys from from the donor vehicle.
Old 10-15-2015, 10:07 PM   #3
SirDigby
Drives: 2007 yaris 3 door
I would think not. immoblizer is usually a separate system. it will work or not. I don't think you'll have problems. I hope you have the vin for the corolla so you can get the brake code. otherwise you'll have to tow it to the dealership.
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 08:28 AM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Technical question about bigger injectors LtNoogie Forced Induction Forum 1 08-14-2009 03:34 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
Technical Question for the Suspension Gurus KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-21-2007 11:31 PM
