Old 10-24-2015, 09:48 PM   #1
tomm9050
Drives: Yaris 2008 HB
Transmission oil recommend
What is the recommended brand of gear oil? will 75/140 work (as opposed to the 75/90 wt?)
http://www.royalpurpleconsumer.com/products/max-gear/ <----??
tomm9050 is offline   Reply With Quote
Old 11-10-2015, 12:21 AM   #2
SirDigby
Drives: 2007 yaris 3 door
no you want 75/90. synthetic is better imo.
Old 11-10-2015, 06:36 AM   #3
Redline MT-90 synthetic 75-90. I just switched to it last week and it makes for much smoother shifts, especially in the morning. It is GL-4 rated and everyone on here who runs it seems to like it a lot
Old 11-10-2015, 09:37 AM   #4
I changed to Royal Purple and am amazed by it. Fixed a problem I've had with 4th gear ever since I installed my 6spd transmission.
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 02:48 PM
Gearbox oil for multimode transmission. matanfr DIY / Maintenance / Service 1 08-16-2010 04:23 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
When should I start using synthetic oil?? trwxxa DIY / Maintenance / Service 68 06-29-2009 06:16 PM
