Old 11-01-2015, 05:30 PM   #1
leo.nix
Drives: Toyota Yaris
Replacing brake pads and fluid
Hello,
My 2007 Yaris Sedan needs brake pads replaced and fluid added.
Where online can I find reasonable OEM parts?
Thanks!
leo.nix is offline   Reply With Quote
Old 11-01-2015, 06:57 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I find Toyota pads last a long time same with rotors as for brake fluid well one should never have to add.
If your adding fluid than you have an issue also keep in mind low pads equal low fluid level and same I just use Toyota brand.
Sent from my HTC One_M8 using Tapatalk
Old 11-01-2015, 08:37 PM   #3
alanwagen
fluid
Originally Posted by leo.nix View Post
Hello,
Thanks!
Your fluid will come back up with the new pads. Do your pads first and then see if you need fluid. Probably not.
brake
Drum brake problem. theb DIY / Maintenance / Service 4 04-23-2014 02:04 AM
Brake fluid capacity? ozmdd DIY / Maintenance / Service 3 11-17-2009 06:45 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
