Old 11-07-2015, 07:38 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Transmission questions
I had a few questions about the manual transmission on my 2010 with around 75 000mi.
1) The shifter does not smoothly go into 3rd gear 75% of the time. There is a crunch feel when shifting into that gear.
2) When I take off from a stop, sometimes my car will studder and the tachometer will wiggle. Maybe I am not giving it enough gas and it's almost going to stall?
3) When shifting from 1st to 2nd, when I release the clutch after shifting into 2nd, the car lunges forward. I shift around 2700-3000rpm.
4) Sometimes my car will not shift into reverse. I have to push the clutch in and release it a few times, shift into 1st gear, then it will go into reverse. This only happens 25% of the time.
Is this normal or should I be worried?
attrapereves is offline   Reply With Quote
Old 11-08-2015, 01:48 AM   #2
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
4) is normal all manuals have this issue; reverse gear has an idler and no synchromesh, so if it feels like it doesn't go in. just put back to neutral, release clutch and then try again.
JudgeM is offline   Reply With Quote
Old 11-08-2015, 06:54 AM   #3
KTS
KTS's Avatar
Drives: Vitz RS
4 - for reverse I depress clutch then go into forth then reverse, others say you could do 1st then reverse.
You could change the fluid to redline MT-90.
KTS is offline   Reply With Quote
Old 11-08-2015, 10:00 AM   #4
attrapereves
Already did that. It seemed to help.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
My 2010 yaris is on its 4th transmission!! Help please Uzairlexus DIY / Maintenance / Service 12 07-16-2013 10:46 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Transmission Questions(fluid change... and other questions) Lafiro DIY / Maintenance / Service 6 04-01-2009 07:52 AM
