Old 11-10-2015, 01:53 PM   #1
Orange
Drives: Toyota Yaris 1999
Question [SOLVED] Fuel tank replacement and baffling
Hi
My Toyota Yaris 1999's fuel tank is leaking due to a rusty exterior. I have looked at the possibilities of sanding it down, but because it is very rusty, and I do not dare to use any power tools on it (because of possible explosion danger), I have decided that I want to purchase a new one.
However, the new tanks I have found surfing around the web are all said to be "empty" inside. My old tank does however contain some parts inside of it, for example some sort of a plastic container right underneath the fuel pump. These parts are sitting fastened inside the tank, and are too large to be removed through the top hole.
I am therefore wondering if I have to worry about new tanks having such parts inside? And, does anyone know exactly what these parts are for?
Thanks in advance. I can include pics if necessary.
Sincerely, norwegian who wants to keep driving his kickass 99 yaris
Last edited by Orange; 11-19-2015 at 09:11 PM. Reason: To inform people that the issue was solved
Orange is offline   Reply With Quote
Old 11-10-2015, 08:43 PM   #2
Actually that is the fuel level sender and pump assembly. It does fit back out through the top hole:
Old 11-11-2015, 08:27 AM   #3
They might be referring to the baffling inside the tank.
Old 11-19-2015, 08:55 PM   #4
Orange
Hi again, thanks for replies, and sorry for being so late to respond myself.
Attachment 56147
If I understand you correctly, you are referring to the parts that sit on the fuel pump. I have already removed this completely.
I think this might be it! It's fun tho that the word baffling could also mean to confuse..
I will include some pictures this time to clarify. Again, the question is, do I need to worry about these parts coming with a new tank?
Old 11-19-2015, 08:59 PM   #5
Those are the baffles. They are part of the tank (as you noticed they are not removable through the pump hole), so they should definitely come with a tank. By empty they likely mean that it does not include the pump and sender unit.
Old 11-19-2015, 09:08 PM   #6
Orange
Thanks a lot! Can't wait to purchase a new one and get my racer back on the road
1999, fuel, replacement, tank, yaris
Just filled up the tank with 91 octane premium fuel darkmoon87 General Yaris / Vitz Discussion 105 10-02-2016 08:35 PM
07 cranks, won't start--no fuel?... tylerwatts53 DIY / Maintenance / Service 18 03-03-2014 05:03 PM
Fuel Tank problem devinlamothe DIY / Maintenance / Service 14 02-04-2009 06:10 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
