Old 11-18-2015, 07:56 PM   #1
those
Drives: 2014 Vitz
Question Rear Wiper not Spraying
Hi
Does anyone know where the connection for the rear wiper spray is under the hood of a 2014 Vitz/Yaris? A short hose for the rear spray is connected to the pump on one end but the other end isn't connected to anything and I can't seem to find it. Water just squirts into the engine when I turn the stalk to wash the back glass. The front one works fine.
those is offline   Reply With Quote
Old 11-18-2015, 09:06 PM   #2
The hose comes off the pump, runs to the fender, then back through the lower portion of the A pillar.
Old 12-05-2015, 07:24 AM   #3
those
Drives: 2014 Vitz
Thanks. Is it supposed to be one long hose running from the pump to the rear or does it connect to a nozzle before entering the fender? The one on my pump is only 6" long.
Old 12-05-2015, 06:14 PM   #4
Sounds like your hose got snipped, as there is not an inline connection there as I recall.
Old 12-06-2015, 08:00 AM   #5
those
Drives: 2014 Vitz
Thanks again. I'll try finding the other end to see if I can connect the two. Failing that I'll find a body work guy who can take apart the front to see if the other end is hiding in there somewhere.
2014 yaris, wipers
Wiper Motor rear k3nty DIY / Maintenance / Service 15 08-24-2014 09:07 AM
Sedan REAR WIPER DIY??? ChitownY@Ris Cosmetic Modifications (Exterior/Interior) 9 02-04-2013 09:53 AM
rear window wiper yaris2010RS DIY / Maintenance / Service 7 03-25-2010 02:05 AM
Rear Windshield Wiper - LB KittenRD General Yaris / Vitz Discussion 2 02-21-2010 10:19 PM
