Old 11-22-2015, 12:58 PM   #1
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Cool Springs available
Due to many factors, I would like to get stiffer rated springs and put them in, along with new struts and shocks.
However, I don't see much available.
I remember with my old Caprice's, I would get high performance front springs, and because they only had fronts available, would end up getting Cargo coils in the rear.
But, I loves what it did for the handling, that predictable, rear wheel drive, bit loose in the turns, and didn't push unless going in too hard, yada, yada.
I don't really want to drop the ride height, nor spend the 2k on the dual adjustable setups.
The bars I put on really helped the go cart like handling I have now, but want to kick it up another notch.
Anyone know of a spring the same size that would be stiffer / higher spring rates ?
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 03:45 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
