Old 11-28-2015, 02:28 AM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
Radio Reception
Never had a problem with radio reception on my '07 with the tall antenna, but radio reception on the '14 is terrible. Could it be the shorter antenna? Anybody else have this issue?
Old 11-28-2015, 02:46 AM   #2
bronsin
bronsin's Avatar
The antenna unscrewed and fell off on my sons 08 and of course the radio didn't work to well. So I made an antenna out of a coat hanger by making a small loop on the end so the screw would go through and bending the wire to make for an upright arrangement.
It worked so well he hasn't bought a new one. Perhaps you could experiment? If its under warranty there always the dealer...
Old 11-28-2015, 04:20 AM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
No problems on my 2014. I'm in the big city though. Are you frequently in rural areas or otherwise far from civilization?
Old 11-28-2015, 08:24 AM   #4
Yeah, short antennas suck.
I've never been in an older car with a huge 3 foot long antenna with bad reception.
Old 11-28-2015, 11:48 AM   #5
kimona
kimona's Avatar
No, I'm in Huntington Beach and surrounding cities... which certainly isn't rural.
Maybe I'll look for an "RC" antenna from the previous generation.
Old 11-28-2015, 01:11 PM   #6
You should try one of the old 3 foot ones for an extreme comparison if you know someone with one you can borrow.
Old 11-28-2015, 04:33 PM   #7
YarTed
Drives: 2015 Yaris 5Dr
Canadian 2015 Yaris in Vancouver area , radio reception is good. Roof mount antenna is pulled out about 4-5 "
YarTed is offline   Reply With Quote
Old 11-29-2015, 03:18 PM   #8
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Radio reception was fine around Phoenix, AZ area on my 2015 with the short stock antennae, though I replaced it with a Visual Garage 040 Super White "Shark Fin" antennae (w/built in fractal antennae) for aesthetic purposes (it looks sooo much better IMO ). I didn't notice any difference in reception here when I made the switch.
Kalispel is offline   Reply With Quote
Old 11-29-2015, 05:00 PM   #9
kimona
kimona's Avatar
Thanks for the replies.
Just to test, I swapped my stock 7" antenna with my friend's 7" antenna from his 2010 CRV. The antennas are virtually identical. Guess what? No more static. So, there must be something wrong with my antenna. Simple fix. I ordered a new antenna from ebay.
Old 11-30-2015, 06:04 AM   #10
bronsin
bronsin's Avatar
Excellent! I always like to hear the happy ending and we don't always hear what solved the problem.
Old 12-06-2015, 10:48 PM   #11
kimona
kimona's Avatar
I bought this antenna from ebay for under $2. It states 9" in the ad, but it measures exactly 8". It fits perfectly and works great. I like it!
http://www.ebay.com/itm/9-Car-Radio-...-/351597728567
Old 12-10-2015, 12:00 PM   #12
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
Apparently, you must have gotten a bad antenna from the factory. I guess even Toyota has a few issues along the supply chain. Luckily, it was a cheap and easy fix.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 12-11-2015, 09:43 AM   #13
Kar98
Drives: 2011 Scion tC
I have the antenna from a Honda S2000 on my 2007 (cheap on eBay), instead of the factory one. Looks better, and reception is great. The "mast" bolts right into the hole where the OEM antenna screws in. Fully interchangeable, no tools needed.
I had no luck with some crappy, 4 inch generic aftermarket antenna.
Old 12-11-2015, 09:51 AM   #14
Picture?
Old 12-11-2015, 01:30 PM   #15
Kar98
Originally Posted by Bluevitz-rs View Post
Picture?
This one sucked, it was like having no antenna:
The one from the Honda S2000 bolts right up:
And the OEM antenna I had, I gave that to somebody whose 2014 Yaris had its antenna broken off. Screwed right into the hole.
Also, if you post a picture at The Car Lounge, it gets resized to fit... just saying.
Old 12-13-2015, 10:46 PM   #16
kimona
kimona's Avatar
My 8" antenna for under $2.
Better FM reception with stock radio? unadilla66 In Car Entertainment + Electronics (audio / video / alarm) 7 06-23-2015 05:56 AM
Radio Reception Problem The Shape In Car Entertainment + Electronics (audio / video / alarm) 3 09-20-2010 06:32 PM
AM radio reception regal In Car Entertainment + Electronics (audio / video / alarm) 3 03-07-2009 10:58 AM
Poor Radio Reception redbluff General Yaris / Vitz Discussion 4 06-16-2006 06:04 PM
Radio Reception redbluff In Car Entertainment + Electronics (audio / video / alarm) 6 04-12-2006 10:18 AM
