Old 11-30-2015, 08:40 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Brakes wont stop squeaking!!
This has been such an annoying problem to me. I bought new pads and rotors back in march from prime choice. Price was very good. I decided to pay a little more and get ceramic pads. I ended up getting the bendix stop by honeywell pads, which are prime choice rebranded, but have the same part #.
I installed the pads, and had a minor squeak. I reapplied brake grease to the shims a few times, and wiped them off after the noise would come back. The coating wore off the shims and the caliper would squeal like no tommorow. It was insane. I also used the CRC disk brake quiet and put quit a bit at least twice, and the noise would come back after a while, but not as bad. Apparently, its the best or one of the best you can use.
After realizing that, I ended up using the abrasive wheel on my grinder to knock all the crap of the shim, and I bought the spray permatex disc brake quiet. No noise as of yet, but I'm expecting them to come back. I also lightly sanded the pads and I've done this more than once. I've used these types of pads for brake jobs I've done for others, and they havent complained. Do you think the shims are crap, or did I just recieve a bad batch?
xdarkxfirex is offline   Reply With Quote
bendix, brake pads, ceramic, prime choice
Shifter Squeaking Sounds, and Brakes xdarkxfirex DIY / Maintenance / Service 0 09-18-2015 08:18 PM
Strange creaking sound whenever applying brakes at stop position. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-04-2015 04:51 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Weird question about my brakes brainless twit General Yaris / Vitz Discussion 8 01-22-2009 10:59 AM
