Old 12-01-2015, 05:39 PM   #1
Kar98
Drives: 2011 Scion tC
So this exists! (Aux/USB jack for aftermarket stereos)
I'm about to install a Pioneer head unit and wondered where to put the USB port and the aux in jack without making it look a spastic with a hacksaw was at work there.
http://www.sonicelectronix.com/item_...USB-35EXT.html
Now I just need to find a spot for the microphone.
Old 12-01-2015, 07:21 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
your map light is where you put your mic.
Old 12-01-2015, 08:20 PM   #3
Nice Find.
This is how I mounted my mic (using a European liftback push to start trim piece and a piece of speaker grill):
Old 12-02-2015, 11:17 AM   #4
Kar98
That seems like a lot of work. I'm thinking about that little rubber apron between the steering column and the driver side glovebox, or one of those rectangular holes near the parking brake.
Old 12-02-2015, 12:43 PM   #5
enviri
enviri's Avatar
Drives: 2010 Yaris
nah takes a few min. route the cable towards teh pillar (take out the glove box and gently unclip the a pillar, but dont remove the apillar), take out one visor and your map light (both you pull out) and the headliner just falls down. All this is done in literally 2 min.
Old 12-02-2015, 02:07 PM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Nice Find.
Never. Cease. To. Impress.
Old 12-05-2015, 05:52 PM   #7
Kar98
If you plan on buying the adapter jack from this thread to use in a Yaris, you'll also need a USB extension cable and a male to female 3.5mm cable, because they ones up there are way too short even to reach in a straight line, much less routed through the console and hidden out of sight.
Old 12-17-2015, 03:17 PM   #8
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Do you have a second cigarette lighter in your car on the passenger side?
If not that might be one of the best places to put it since it's close to the head unit and you won't need any extensions.
You can then plug in your phone and leave it in the storage area underneath the climate controls.
Old 12-17-2015, 06:50 PM   #9
Frank the Tank
Drives: 2007 Toyota Yaris
what deck are you using?
im thinking about a mvh-x380bt
Frank the Tank is offline   Reply With Quote
Old 12-17-2015, 10:34 PM   #10
Kar98
I got this one:
http://www.yarisworld.com/forums/sho...&postcount=155
(contains parts list)
Twice as much as the one you're thinking off, but I really don't care for the dash kits with storage underneath a single DIN aftermarket stereo. Gotta have that OEM look ;)
Old 01-06-2016, 01:42 AM   #11
invader166
Pumpman
If your headunit does not have a rear USB input (like mine ) you can still use the USB connection to charge your phone/GPS/other device with a voltage regulator unit like this:
http://m.ebay.com/itm/271904352420?_mwBanner=1
I ordered one to use in my car. Now I just need to figure out which wires to tap into.
Old 01-06-2016, 10:54 AM   #12
Kar98
Well if you just wanna charge your phone/GPS/other device, you can just use the cigarette lighter socket.
Old 03-29-2016, 03:50 PM   #13
Kar98
Just the one, and I've popped out the factory aux-in adapter next to the parking brake and replaced it with the one from Sonic Electronix. Cleaner look.
Either way, I've since ripped everything back out and moved the entire collection into my new car.
Does the Toyota Yaris come with a jack? RMcG Third Gen Yaris General Discussion 7 08-20-2015 11:03 AM
Jack Stands, Floor Jack and Oil Filter? 268i DIY / Maintenance / Service 11 08-03-2014 04:32 AM
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
