#1 |
conundrum562
Drives: Toyota Yaris 2007 S Join Date: Jun 2010
So I have my S/C on Medium setting and when I WOT from stop to about 80MPH and after I just brake to park it. Once I do that I smell a strong burner rubber smell from inside the hood... Not sure what it is, does anyone have the same problem or know anything about this?
![]() Appreciate any help.
--------------------------------------------------------------- BLITZ SC | CERAMIC 6301 BEARINGS | MICRO-IMAGE CRANK | NST PULLEYS TRD 71C THERMOSTAT | 1ZZ INJECTORS | TB SPACER | BLITZ SRI NGK PLUGS, COILS & MAF | DC HEADERS | CUSTOM 2.25" EXHAUST GTSPEC STRUT BAR, MID & 4-PT LOWER BRACES TANABE FRONT & WHITELINE REAR SWAY BARS W/ POLY BUSHINGS TBW SKID PLATE | FULLRIVER AGM BATTERY | MOBIL 1 EP + PROLUBE
#3 |
Your belt is slipping.
#4 |
conundrum562
HA-HA I just got it re-tightened...? I wonder if it's my grounding wires or header. The smell seems to come from the right side of the 1NZFE engine. The belt side doesn't really smell. For sure it's a distinct plastic burning smell.
#5 |
![]() Drives: 2006 Yaris 1300 Join Date: Jan 2014
Might be your caliper piston that's staying engaged? I recall the plastic smell since I fixed mine 2 weeks ago.
| Mga Bagong Kayaris ! ! ! | syntax | Middle East | 749 | 04-26-2021 02:40 AM |
| Burnt smell in cabin at high speed in cold weather | grilled cheeseus | DIY / Maintenance / Service | 13 | 12-15-2018 07:29 PM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| Burning Rubber Smell??? :S | colinr5779 | Yaris TS Talk | 12 | 02-27-2010 11:55 PM |
| smell like a burning rubber when accelerating | highwaypass | DIY / Maintenance / Service | 5 | 05-25-2009 08:15 AM |
