#1 |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
1zz Throttle Body Question
i found the 1zz throttle body for my 2012 yaris sedan..
i heard there is different types of throttle body sizes from 1zz.... ![]() after installing 1zz tb, do i have to fabricate my intake..currently i use drop in cause i do not like intake kit that i used previously..im guessing 1zz tb has bigger diameter and upgrade is a must...
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
You can manufacture one if you like, but you can also modify the existing air intake hose, to make it fit the new TB.
For mine, I went to the hardwear store, bought a 2" mechanical drain pipe connection (2.5" would be better, but coudn't find that size) cut off the TB end of the OEM intake hose, then cut the same size from the drain pipe connection, and "glued" them together with some leftover Permatex gasket maker I had. 8 hours later installed the hose, and everything fits like a glove. You can even use it on the regular 1NZ TB. Just tighten the hose clamp more. ![]() (Permatex, I seriously put that s**t on everything! )
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#3 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I just stretched my silicone gasket that cam w/ my intake. It was tight but a little silicone lube and some strength got it to stretch on there. I can't fit any clamps I have on it so i'm just using zip ties. Never any issues as the silicone fitting is tight on there by itself anyways.
#4 |
feed my pet
Tooter taught me that I could reverse the stock hose and you just need to stretch the TB side to fit it in so that worked well.
Couple of months back I installed a TB spacer and that made the stock hose a bit too long so its pushing into the air box and the lid does not sit in properly. rabbito you are in the land of parts paradise. There's someone over there selling the MAF adapter and you could use hoses and couplers to link both ends.
#5 |
![]() ![]() Drives: Yaris '05 1.3 Hatch "R.I.P." Join Date: Aug 2014
Ja, I had to also turn my stock intake hose around and stretch it over the 1zz TB with a proper clamp when I was using it, it worked well \m/
Fluxtasy that is one neat engine bay! :D |
#6 |
feed my pet
lol yes but that isn't my car
| Build your own throttle body spacer! | SirDigby | Performance Modifications | 19 | 07-18-2026 01:38 PM |
| FS- 1ZZ Throttle Body, Spacer, NST SSK | MGargano | Items for Sale by private party | 9 | 09-01-2010 08:48 PM |
| 1zz throttle body | mrbond | Items for Sale by private party | 9 | 07-22-2010 04:54 PM |
| [Buy] throttle body 1zz yaris 1800cc to 1500cc TS | Nets | Items for Sale by private party | 2 | 04-25-2010 10:27 AM |
| FS: 1ZZ throttle body and Fujita intake | mrbond | Items for Sale by private party | 25 | 09-08-2009 10:21 PM |
