Old 12-10-2015, 07:37 PM   #1
buzzbuzz
Drives: 2007 Yaris
Yaris 2007 4 Door Bulb for Heat Venter Switch
The panels are out and the cover is off but where the heck is the bulb, the center AC light is ok it's just the outside light that's out.
Lots of control wires behind this, can anyone tell me how to get at this bulb without me breaking all kinds of plastic?
buzzbuzz is offline   Reply With Quote
Old 12-10-2015, 07:46 PM   #2
Once you disconnect the white plastic piece for the cable, you will see a recessed area in the center of the back of the knob. The bulb is mounted into a plastic carrier there. Just use a flat head screwdriver to release it.
Old 12-10-2015, 07:50 PM   #3
buzzbuzz
Drives: 2007 Yaris
I guess I disconnect the electrical connector plus the steel control cable that moves the vents?
Do I leave the big white plastic block where it is? or do I try to get this out?
Old 12-10-2015, 08:01 PM   #4
The white block does have to be removed. There are a couple of slots in the black plastic that tabs of the white part snap into. Once you release them the whole cable holder is free.
Old 12-10-2015, 08:05 PM   #5
buzzbuzz
Drives: 2007 Yaris
So you leave all the cables attached to the white block and just inch out the white plastic block and the bulb is in there?
I would assume there are plastic tabs that need to be lifted to pull out the white block?
Old 12-12-2015, 03:29 PM   #6
buzzbuzz
Drives: 2007 Yaris
I see the green bulb but it wont come out now it seems loose but will not come out?
Old 12-12-2015, 09:59 PM   #7
Once you rotate it counterclockwise to release it you will either need to tilt the control panel to get it to fall out, or reach in with a small needle nose pliers to pull it out.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
