Old 12-12-2015, 09:10 PM   #1
wuxiao0715
Drives: 2008 Yaris
No lights on air conditioning switch at night
Hi, When I was driving on night, I found there are no lights on these air conditioning switch. see the photo I linked.
Is this normal? Or, those lights on these switches are broken.
Because it's not quite convenient when i was driving and need to tune those switch.
Thanks
wuxiao0715 is offline   Reply With Quote
Old 12-12-2015, 09:53 PM   #2
Thanks
Check the position of your dimmer rheostat (the knob by your left knee).
Old 12-17-2015, 11:10 AM   #3
wuxiao0715
Drives: 2008 Yaris
Then, something must be broken.
I tuned the dimmer rheostat, there're still no light. And the light on the dashboard doesn't change too
Old 12-17-2015, 07:52 PM   #4
If the brightness of the instrument cluster lights does not change when you adjust the dimmer rheostat, then either your headlights are not on (the headlight switch needs to be on to trigger the illumination of the AC knob lights) or the dimmer rheostat is bad or unplugged.
Old 12-17-2015, 11:04 PM   #5
wuxiao0715
Drives: 2008 Yaris
Hi, Thanks for your response.
At the second I saw your comment, I went to the car and tried again. It still doesn't work and seems like the dimmer rheostat is bad or unplugged. I want to fix this, is this expensive? Or I can repair by myself?
Old 12-17-2015, 11:20 PM   #6
Do you see the headlight indicator light come on on the cluster?
For checking the rheostat you can open and remove the little storage cubby on the lower left of the dash. Once you do that you can reach in and verify that the connector is plugged in.
Old 12-17-2015, 11:50 PM   #7
wuxiao0715
Drives: 2008 Yaris
Yes, I can see headlight indicator light when I opened the headlight on night. Does this mean something?
Old 12-18-2015, 05:50 AM   #8
It means that the signal is being fed to the dimmer to tell it to go into night mode.
Old 12-18-2015, 09:15 AM   #9
wuxiao0715
Drives: 2008 Yaris
So, The conclusion is?
Anyway, I may go to check this problem today
Old 12-18-2015, 09:44 PM   #10
That the problem is with the rheostat or its wiring.
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 10:07 AM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Finish Sedan S Intake, Paint Caliber, Air Vent Lights jamal1984 Performance Modifications 9 03-12-2007 11:57 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
