Old 12-14-2015, 12:39 AM   #1
Tim Miller
Drives: yaris
transmission wont go into OD
Hello
I have a 2008 yaris that wont go into OD. I am getting a p0717 code.
Input/turbine speed sensor no signal. I understand that it wont shift into OD until the car is warmed up. that doesnt seem to be the issue.
I have 2 wires that do not seem to be connected to anything any ideas what they are??
I was also wondering if anyone could tell me where the coolant sensor is
in the pictures I was curious what those wires are for and what they are supposed to connect too
also is there a place I could down load a wiring diagram of the car
thanks
Tim Miller is offline   Reply With Quote
Old 12-14-2015, 07:36 PM   #2
The violet/blue wires on the connector on the left are supposed to be plugged into the VSV Purge valve which is a grey block with hoses coming out of it that should be mounted to that L shaped metal bracket on the left.
The turbine sensor on the tranny is the black one with the 2 pin connector plugged into it just behind where the tranny dipstick enters.
Old 12-14-2015, 11:56 PM   #3
Tim Miller
Drives: yaris
thank you!!!
any other insights you might have? Im trying to avoid taking it to a toyota dealer which is 3 hours away
Old 12-15-2015, 05:36 AM   #4
Originally Posted by Tim Miller View Post
thank you!!!
The sensor is likely the issue, as the code points to it and it would indeed prevent the tranny from going into OD.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
My 2010 yaris is on its 4th transmission!! Help please Uzairlexus DIY / Maintenance / Service 12 07-16-2013 10:46 PM
Transmission & Reverse Twistoffate0817 DIY / Maintenance / Service 4 08-28-2012 06:50 PM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
