Old 12-17-2015, 02:04 PM   #1
Strat
Drives: 2008 Yaris 4-door hatchback
Angry Backseat won't stay on!!! Help!
I checked it out and there are plastic clips in the holes where the hooks at the bottom of the backseat are supposed to go into. Unfortunately, the clips don't seem to do anything anymore.
I put the seatbelt clips through the holes of the backseat but that isn't enough to keep it on.
Unless somebody posts a good solution to this irritating problem, I won't have much choice but to remove the clips by force and use heavy-duty plastic ties to keep the seat from moving.
Strat is offline   Reply With Quote
Old 01-19-2016, 03:14 PM   #2
spookybathtub
Drives: 2007 Yaris HB
I remove my backseat about once a month, and have been doing so for 4 years. (I swap it with a plywood deck to hold more cargo). Those two big plastic clips are a little chewed up, but still hold just fine. I'm curious what you're doing to the backseat to make it wear out so fast.
spookybathtub is offline   Reply With Quote
Difficulty Getting into Backseat bewley General Yaris / Vitz Discussion 3 11-11-2012 02:45 AM
Backseat question.. ArmyYaris Cosmetic Modifications (Exterior/Interior) 6 07-04-2012 12:32 PM
Brake lights stay on OttenVT03 DIY / Maintenance / Service 4 12-14-2010 11:21 PM
BackSeat REVIVAL PETERPOOP DIY / Maintenance / Service 16 04-06-2010 11:31 PM
Split 60/40 Backseat Lisa Hasler Willing to Buy by private party 11 10-19-2009 12:15 AM
