Old 12-18-2015, 09:50 AM   #1
colombia1008
Drives: yaris
Question Need help 08 Yaris (speedo-p/s-abs-brake)
Hello i have a 2008 yaris which had a low oil pressure issue , we got it fixed by changing the crankshaft bearing (removing all the engine ) , but after that a wired issues appeared : the speedometer not working and causes heavy steering according to yaris service manual . there is no speed sensor in transmission , so i tested the front wheel speed sensors with a multimeter and they are just fine , i cheked every fuse in the car (all good ) . i tried a Bluetooth OBDII scan tool with no luck (my yaris uses M-OBD) .
note : i have one of rear abs sensor not working since a bought the car and i know it's causing abs/brake lights but the speedo was working fine .
colombia1008 is offline   Reply With Quote
Old 12-18-2015, 09:43 PM   #2
Considering that your engine was pulled to replace the bearing you should check to make sure that all connections were restored. The wheel speed sensors feed directly to the ABS ECU (which is below the brake master cylinder). Check to make sure that the connector is plugged into it and then check to make sure that the wiring between it and the front wheel sensors did not get pinched and damaged.
Old 12-19-2015, 06:36 PM   #3
colombia1008
Drives: yaris
thank you CTScott for repliyng ,
problem found and fixed by using a scanner (launch x431) : the front abs sensors (the one in driver side is used as vss)
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
yaris abs brake light speedometer and electric powersteering issues dave van muyden DIY / Maintenance / Service 4 10-26-2013 02:33 PM
ABS brakes / Would you buy a Yaris without them? 3cyltrbo General Yaris / Vitz Discussion 66 03-26-2011 08:21 PM
