Old 12-20-2015, 01:40 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Cleaning Electronic Throttle Body and IAC??!
Is this a good idea? I've heard of it causing problems later. I decided to clean my maf sensor, but leave the body alone.
What do you think?
xdarkxfirex is offline   Reply With Quote
Old 12-20-2015, 01:56 PM   #2
It won't cause problems unless you leave the battery connected or the throttle body connector plugged I and use your hand to open/close butterfly valve.
Make sure you unplug either the connector or the battery if you're going to be using your hand to open/close the butterfly valve.
Old 12-20-2015, 04:01 PM   #3
xdarkxfirex
Cleaned it with CRC Sensor Kleen, no problem, except a ton of salt caked around when the plastic intake hose sits. Started up after a few hard cranks and ran, no problem.
car, mass airflow, throttle body
vitz high idle problem after cleaning the throttle body. dindy DIY / Maintenance / Service 20 11-07-2012 05:05 PM
