Old 12-26-2015, 03:20 AM   #1
LeetViet
Drives: 07 Yaris 4DR
Can't open hatchback trunk -- recommend locksmith?
Can anyone recommend a locksmith in the GTA that could fix my Yaris's hatchback trunk not opening?
It used to be stuck unlocked (which was fine), but now it won't open at all. I still can't lock/unlock it.
LeetViet is offline   Reply With Quote
Old 12-26-2015, 06:47 AM   #2
You can climb into the hatch area, pop off the small cover in the lower center of the hatch and simply flip the silver lever to open it. Once you do, you can pull off the cover to access the entire lock assembly and see what the issue is. Typically it just needs cleaning and lubrication.
Old 12-26-2015, 08:59 AM   #3
What area of the GTA are you in. If you're east end you could come by and I could help you out if you can't get it open on your own.
Old 12-26-2015, 06:10 PM   #4
LeetViet
Could you post a picture? I'm not sure what I'm looking for.
Thanks for the offer. I'm in the west end, but I can come to you tomorrow if you're free.
Old 12-26-2015, 07:34 PM   #5
Check out my DIY in the link below, as it shows the details of how to remove the hatch cover, once you get it open. The latch that you need to release is the one shown at the top of page 4 and the small cover that you need to remove is not directly shown, but is at the center of the lower portion of the hatch.
www.yarisworld.com/forums/showthread.php?t=39677
Old 01-08-2016, 09:07 PM   #6
Frank the Tank
Drives: 2007 Toyota Yaris
I sprayed some, actually a lot, wd40 in the keyhole and it solved the problem. You have to let it sit for a day or two for it to work.
Frank the Tank is offline   Reply With Quote
Old 01-16-2016, 10:07 AM   #7
LeetViet
Sorry for the delayed response. I was able to open the trunk recently with no change on my part. Still won't lock, but that's another issue.
2010 Yaris Liftback (LB) / Hatchback - Prewired for Trunk Actuator? bad_bwoy007 DIY / Maintenance / Service 26 01-18-2021 05:09 AM
Hatchback Trunk Cylinders Betrivent DIY / Maintenance / Service 75 06-14-2020 05:55 PM
Hatchback Trunk Cover KrazyDawg General Yaris / Vitz Discussion 24 11-08-2010 02:00 AM
is this trunk kit ok for our hatchback ?? vten DIY / Maintenance / Service 3 10-31-2009 02:49 AM
