Old 12-30-2015, 07:27 PM   #1
SHI2RG
Drives: 2008 Toyota Yaris
2008 Yaris - idles at a lower rpm
Just flushed my automatic transmission.. Took off and cleaned the pan and replaced the screen filter. The car runs way smoother than before... Many thanks for all the help.
The other issue I am seeing is that the cars is idling at around 500 RPM when idle. Wonder what could be causing this to happen and what can be done to rev up the rpm to around 650, which I believe is the normal for Yaris.
As always thanks to all your time and help.
SHI2RG is offline   Reply With Quote
Old 12-30-2015, 08:31 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
500 is normal
Sent from my Note 4 or S6 depending on my mood :p
Old 12-31-2015, 04:32 AM   #3
SHI2RG
Originally Posted by Exiwolfman View Post
500 is normal
I am observing 2 issues here:
1.) Although on "Drive" the car rolls back when idling on a slight slope.
2.) The entire vehicle seems to shake at that RPM.
I personally believe that the idle RPM should be between 650-750.
BTW I did replace my Battery too with a CCA rating of 575, which I believe is higher than required. Could this be causing the problem?
Old 12-31-2015, 11:35 AM   #4
thetut
Drives: 2007 4dr sedan
See here: http://www.yarisworld.com/forums/showthread.php?t=26607
thetut is offline   Reply With Quote
Old 12-31-2015, 03:53 PM   #5
SHI2RG
Originally Posted by thetut View Post
Thanks!
I can see it has started to get better now.
Old 01-01-2016, 10:05 PM   #6
slipaway172
Drives: 2010 3dr
My yaris had a rough idle almost to the point of stalling, it was a filthy throttle body
Sent from my SAMSUNG-SM-G920AZ using Tapatalk
slipaway172 is offline   Reply With Quote
500 rpm, idle, low
Quick Question about the 2008 Yaris: doog DIY / Maintenance / Service 5 11-29-2014 12:26 PM
FS: 2008 Yaris HB LtNoogie Cars for Sale by private party 1 05-30-2014 12:47 PM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 09:46 AM
