#1 |
![]() Drives: 2008 Yaris hatchback Join Date: Aug 2015
Having a problem when trying to fill the tank.
Ive got an issue when trying to fill my tank. As soon as i hit the trigger on the pump it shuts off like the tank is already full. I had the same issue with my 06 Mustang,a combination of a convoluted filler pipe and an Evap canister that couldnt keep up with the fuel flow. Anybody had a similar issue?
There are a few threads on here about that issue. The cause is the vent tube being plugged. It is the small tube that runs down the side of the filler tube.
#3 |
filler
Thanks!
| Warrany Service Problem? | 2009Yaris | General Yaris / Vitz Discussion | 4 | 03-31-2011 04:56 PM |
| Problem with my car | rakhan01 | DIY / Maintenance / Service | 8 | 12-03-2010 05:12 AM |
| When you fill up.. | kaymm | Canada | 28 | 04-13-2007 08:59 PM |
| My problem with my car; help(gas econ) | Lafiro | General Yaris / Vitz Discussion | 42 | 11-14-2006 08:32 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
