Old 05-10-2007, 01:40 PM   #1
kurokoma-kun
Drives: 2007 Yaris HB
painted center caps on steelies
Just thought I'd share my extremely cheap little mod with everyone. I liked the look of steelies so I took off wheel covers and covered hub w/ metal cap.
I painted gloss black, then sprayed again with sparkly clear (duplicolor Effex--highly recommend for anyone wanting to a match paint job that has multi-color sparkle in it). Also sprayed backs of mirrors for extra sparkle--seemed a bit dull compared to body color.
Very happy with results and will probably spray emblems to match.
Old 05-10-2007, 03:17 PM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
did you use the NAPA grease cups #730-2411? Did they fit nice-n-snug?
blacksan is offline   Reply With Quote
Old 05-10-2007, 04:02 PM   #3
kurokoma-kun
Yes they are napa part and no they did not fit snug. Used duct tape inside to fit, then stuck on with gob of epoxy. I thought they would be gone before lunchtime, but a couple days and still secure.
Old 05-10-2007, 04:05 PM   #4
blacksan
blacksan's Avatar
Hmmmmm, they where loose? If that is the case then you could just flare out the skirt by making mandrel, or by simply bending out symmetrical contact points with pliers.
Old 05-10-2007, 05:11 PM   #5
kurokoma-kun
You are talking to a girl here... i know which is bizness end of hammer and can jerry rig stuff pretty well but wtf is a mandrel?
Old 05-10-2007, 05:23 PM   #6
blacksan
blacksan's Avatar
I just walked out to the garage and put mine on for the first time and they are snug. Take a cresent wrench (adjustable) and tighten it on the inner skirt of the grease cup. Make a slight bend inward (I did it in 4 places) and test fit. When I had the cap snugly fitted I just taped them on with a rubber mallet until they where seated. Let me run them a few days and I will give you an update.
Old 05-10-2007, 05:34 PM   #7
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Glad to hear you found them BLACKSAN
Old 05-10-2007, 05:56 PM   #8
blacksan
blacksan's Avatar
I was kind of shocked to find out that they where too big? I polished them up and bent/tweaked them until they where sung. I am going to find a better system of fastening them this summer, or caps that actually fit the ID vs OD of the wheel hub.
Old 05-10-2007, 06:27 PM   #9
kurokoma-kun
Originally Posted by blacksan View Post
Take a cresent wrench..Make a slight bend...etc
Thanks for explanation--I may try it when these pop off eventually...
will be looking for pics blacksan
Old 05-10-2007, 06:31 PM   #10
Chris07LB
Chris07LB's Avatar
Should have measured them first then. I guess the Scion steelies arn't the same then afterall.
Old 05-10-2007, 06:31 PM   #11
blacksan
blacksan's Avatar
Let me make shore that this works and I will get you visual explanation of the procedure.
Old 05-10-2007, 06:36 PM   #12
blacksan
blacksan's Avatar
I did not study the pics of Scion wheels closely, but I can not imagine they are not the same. Does this look like it is on the outside, or inside of hub to you?
Old 05-10-2007, 07:21 PM   #13
uncleyaris
Great job on the paint, and thanks for the heads up on the caps. It's a good option for those steelies.
Old 05-10-2007, 08:26 PM   #14
blacksan
blacksan's Avatar
Well, it looks like utility trailer parts shop will be the best bet for the correct size grease cap/dust cover. I have not pulled mine to measure the hub as of yet, but on a bright note after a brief test of the bend the tab fit I performed this evening all is well.
Old 05-11-2007, 09:55 AM   #15
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
Dang, Blacksan, that's a fine lookin' set of steelies! Certainly a better alternative than hubcaps.
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Seat cushion for thigh, center armrest left armrest BMGYaris Cosmetic Modifications (Exterior/Interior) 2 07-03-2009 11:51 PM
Hub Caps?? barryware Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-15-2007 11:34 AM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 06:45 PM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 07:09 PM
