Old 05-10-2007, 04:18 PM   #1
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
HID Help Quick
Hi
I'm installing this HID i got today, and i got some problems, can you guys help me out quick?
Here are some pics.
Plugs everything in, but the lights not on. Did i plug the connector in right?
Old 05-10-2007, 05:37 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
In your first pic, keep the black wire where it is, switch the other.
By mistake, I had mine hooked up backwards, and a simple switch-a-roo corrected it.
It "could" be it.. try it.
Old 05-10-2007, 05:43 PM   #3
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
is that HID kit or real HID projector.
u got 3 wires coming out of the car.
So on the pass side:
black = positive
green = high ground
blue = low ground
driver's side:
grey = positive
brown = high ground
green = low ground
Now. If your thing doesn't use high beam, don't worry bout the high ground cable.
make sure tehy all go to a relay first. Than from there it goes int othe ballast with a ground.
Low ground will go into relay, 85 or 86. positive will go into 85 or 86.
30 goes to battery, 87 (not 87a) go to ballast with a direct ground wire thats hooked to the negative of the battery. than from ballast it goes to bulb.
Give it a shot.
-- Blen
Old 05-10-2007, 05:48 PM   #4
Blenjar
Blenjar's Avatar
Let me know if your thing runs high beams.
Also if you don't use relay...umm...i wouldn't recommended cause I don't think it will work...see common positive is always there, so does low ground for low beam (make sure DRL is not installed).
86(positive always active) and 85(active only when turned on), when they make contact, it activates 30 (battery) and 30 activates 87 which goes to ballast (ground is also in ballast (direct to negative battery))
Makes sense?
correct me if im wrong..
-- Blen
Old 05-10-2007, 05:50 PM   #5
Blenjar
Blenjar's Avatar
Also here's a hint, make sure your ground is WELL GROUNDED...
if its not it wont work n u will think its something else that's broken.
Ground it nice and tight.
-- Blen
Old 05-10-2007, 05:53 PM   #6
Blenjar
Blenjar's Avatar
http://www.comagination.com/parts.htm
I bought mine there..they do it in like 3 business days.
go to pepboys n buy #14 thickness cables or w/e.
if u decide to buy relay socket and relay..
www.partsexpress.com
OR you can buy harness for 20 bux shipped from mobileHID guy here..
I think that's easier and cheaper IMO.
I bought two from him to practice my thingy...he makes good harness.
-- Blen
Old 05-10-2007, 06:22 PM   #7
jamal1984
-- Blen
Thank you chriss, i will try it now.
Hey thanks Blenjar, i've been looking for that kindda connection. but don't know where to buy it. Great site.
I will post some pics and stuffs soon if it's working.
Old 05-10-2007, 06:24 PM   #8
jamal1984
Makes sense?
-- Blen
This thing is single beam only, no highbeam, i dont have the money to get the HID Bixenon yet. This is all i can get at the moment so far.
Old 05-10-2007, 06:34 PM   #9
Chris07LB
Chris07LB's Avatar
If its a simple plug n play kit, rule out the simple stuff first.. Blen is correct though about running a relay, rather then just plugging into the stock connector. Powering off the battery is the best way even with just a regular plug n play kit (as opposed to a complete retro fit).
Old 05-10-2007, 11:30 PM   #10
jamal1984
oK, FINALLY i got it fix, and here are the problems. and here are few pictures.
THANK YOU CHRISS AND BLENJAR for helping me out, i'm really appreciate yu guys.
Old 05-11-2007, 07:06 AM   #11
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Do yourself a favor and get a proper harness. If you can't afford a real HID system, you surely can't afford to have your electrical system diagnosed and repaired after you screw it up by wiring directly to the factory harness.
Old 05-11-2007, 09:04 AM   #12
jamal1984
Yeah that is what i'm going to do now, Blenjar gave me the site, i will get it from them. what do you mean by the Real HID System?
Old 05-11-2007, 09:06 AM   #13
Chris07LB
Chris07LB's Avatar
Again, shoot me your email sir! I have something for you to look at.
Old 05-11-2007, 06:19 PM   #14
Blenjar
Blenjar's Avatar
HIDMobile or MobileHID guy here sells harness for $20 bux SHIPPED.
GOod price IMO.
He's no longer a vendor but go http://www.mobilehid.com/
Contact him and say u just want harness.
Paypal and get it in 3 biz days.
-- Blen
Old 05-11-2007, 10:17 PM   #15
jamal1984
one quick question. What is the different between Plug n Play and the one from MobileHID which is you have to wire it in your Battery (i guess) correct me if i'm wrong. Are they the same quality?
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
Closest to a HID kit? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 62 03-18-2009 12:44 AM
HID worth It? jamal1984 Performance Modifications 6 01-31-2007 03:42 AM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
My 6500k H4 HID Review [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 74 10-10-2006 07:19 PM
