Old 01-15-2016, 03:33 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Large DBW Throttle Body with mounting plate For Sale
As the title says. This DBW throttle body isn't for the faint of heart. Measuring in at over 76mm this beast would be a perfect compliment to a serious build. If you have a Golden Eagle Intake Manifold or other custom manifold this TB would be a match made in heaven especially if you were to complete the setup with a ported head.
This unit was tested by CTScott to not throw a CEL and the idel screw can be adjusted with ease.
The mounting plate was designed to bolt as well to the OEM bolt points for the 1nz Intake Manifold.
Why am I getting rid of it? Simply because I went with a cable conversion instead.
Asking for $110 shipped to the US.
Puerto Rico will need a zip verification to see what or if I would have to add any to the price.
Elsewhere in the world will require additional funds for shipping.
Sent from m-o-b-i-l-e
Old 01-15-2016, 04:54 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
For reference, the stock TB plate is ~45mm, a 1ZZ is ~55mm, if I recall correctly.
What did you use for gasket material?
Old 01-15-2016, 09:36 PM   #3
fnkngrv
fnkngrv's Avatar
Permatex Ultrablack
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
1zz Throttle body review/tips Black_griffin6 Performance Modifications 154 11-18-2021 03:35 PM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
