Old 01-15-2016, 09:04 PM   #1
Snowball2009
Drives: 2009 yaris hatchback manual
wiper upgrades
Wiper upgrades, wondering which part to use:
Wiper switch 8465252110 ? Or 8465212A20 ? What's the difference between these two? Currently have basic front and rear wiper function, you know 1-3 front w/mist, 1 rear w/mist. The goal is just to add a time delay function to front wiper and leave rear as is.
Snowball2009 is offline   Reply With Quote
Old 01-16-2016, 01:39 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
http://www.yarisworld.com/forums/showthread.php?t=15512
Old 01-16-2016, 06:26 PM   #3
Snowball2009
wiper
Thanks, for install info. This Will be helpful. Mostly though, I'm confused about which OEM time delay wiper part I want to get. The part in the link ( 8465252110 ) looks to be meant for a rear wiper with 2 rear settings, one of which will not totally work without additional rear wiring for the rear wiper with this install. I'm wondering if anyone knows if ( 8465212A20 )might also work, and if maybe it's more what I need. Which is a switch that has intermittent/mist time delay up front and just 1 setting with mist in the rear. The description for the 12A20 part number is confusing to me and I'm not really sure what functions it actually has. Think what I need is a part description de-coder.
Old 01-28-2016, 04:41 PM   #4
xdarkxfirex
Drives: 2015 yaris le
I didnt bother with the OEM. When I bought it, someone had put the cheaper standard metal wiper blades.I replaced then last spring when they were streaking. I bought cheap hybrids, and they broke during a snow storm last month :(
I ended up buying michelin all season hybrid wiper blades from a local auto parts store for $9 in canada. No regrets so far, seems like a good value
xdarkxfirex is offline   Reply With Quote
Old 01-30-2016, 09:59 AM   #5
marspike
marspike's Avatar
Drives: Yaris 2014, Y. HSD 2013
Great to known this trick!!!
marspike is offline   Reply With Quote
Old 01-30-2016, 03:08 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by Meeksworth View Post
I upgraded the rear wiper to a 16" from the stock 12". The 16" fits perfectly. I suspect the 12" which is the shortest one available was only installed stock due to costs.
I looked closely at my rear wiper. Because of the design of the OEM blade, I can't install a longer refill. So, I guess you replaced the blade. Which blade did you find that fits the arm?
Old 01-30-2016, 03:31 PM   #7
kimona
kimona's Avatar
Okay. Thanks a bunch. I'll check out the Rain X blades. I didn't realize aftermarket blades were designed to fit unique OEM rear blade wiper arms.
Old 05-26-2016, 11:10 PM   #8
Racecartimmy85
Drives: 2009 Yaris 5 door
A little late to the game but I just bought a 09, and noticed the front wipers are both a little short. The leave a rather large unwiped triangle area on the passenger side and a good size area in the upper driver's side corner. Has anyone put larger wipers on either front blades?
Racecartimmy85 is offline   Reply With Quote
Old 05-27-2016, 11:45 PM   #9
Tapokata
Drives: 2009 Yaris
It's the driver side that is too short on my 09 LB. The size guides at the store will tell you to replace with a 26" blade. Use a 27" instead. It will fit, and the annoying Bermuda Triangle vanishes.
Tapokata is offline   Reply With Quote
Rear Wiper Intermittent Delay Timer Mod toy_toronto DIY / Maintenance / Service 36 07-08-2016 08:04 AM
Rear wiper motor gone alex22808 DIY / Maintenance / Service 1 11-05-2014 11:27 AM
Rear Wiper "Coverage" Problem Solved Onwrdigo Third Gen Yaris General Discussion 5 06-20-2013 06:48 PM
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
