Old 01-19-2016, 04:39 AM   #1
drinna28
Drives: 2007 YARIS SEDAN
random horn honking while driving. plz help
my 2007 yaris sedan just started to intermittently honk while driving. noticed it occurred more when the weather starts getting warmer and when i adjust the side mirrors and lower the front passenger window.
what could be causing this to happen and how do i fix it?
drinna28 is offline   Reply With Quote
Old 01-19-2016, 09:26 PM   #2
It could be broken insulators on the steering pad. There are plastic pieces which isolate the airbag frame from the steering wheel frame. If someone ever punched the steering wheel, the insulators can easily break and will eventually allow the horn to stay on.
Old 01-20-2016, 03:02 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
And as well all know, punching steering wheels can definitely happen, amirite!
Guys?
Old 01-25-2016, 08:04 PM   #4
drinna28
would replacing the spring cable fix that issue? the mechanic had told me that was what's wrong
Old 01-25-2016, 08:06 PM   #5
drinna28
how would i fix that? lol. I've never punched my steering wheel��
Old 01-25-2016, 08:48 PM   #6
If your spiral cable has not been replaced for the recall it could indeed be that. For the other issue the solution is unfortunately to replace the airbag, as you can't buy the plastic spacers to replace them separately.
Old 01-26-2016, 03:09 AM   #7
drinna28
thank you for all your help :)
Old 02-02-2016, 08:27 AM   #8
Confectious
Drives: T1
i had a problem where my horn was not working due my steering wheel being slightly bent and therefor could not reach the contact points when pressed in. I would first take the steering wheel cover off to see if it solves your problem. Also check if it happens when the steering wheel is pressed or when it turns
Confectious is offline   Reply With Quote
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
2nd accident 100% my fault in every way in almost 1.3 million miles of driving nookandcrannycar Off-topic / Other Cars / Everything else Discussions 20 01-16-2015 08:44 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 05:26 PM
