Old 01-22-2016, 01:48 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
AVS In-Channel Ventvisor Pics
Anyone have pics of AVS In-Channel Ventvisor pics on their three-door Yaris? I've found a few via searching, but not sure if they're in-channel or not.
Old 01-23-2016, 06:32 AM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
AVS makes them for the Yaris both ways. Stick on and in channel.
Old 01-23-2016, 08:54 AM   #3
So these are what you are requesting? There is no question that these are in-channel.
Old 01-25-2016, 12:52 PM   #4
Thirty-Nine
Right, but are they AVS or Weather Tech? (Or someone else's?)
Old 01-25-2016, 01:04 PM   #5
Thread that the pic came from states they are AVS. I wouldn't have posted otherwise.
Old 01-25-2016, 01:26 PM   #6
I have AVS's on all 4 doors on my sedan. They look exactly like the the ones in the pic WeeYari posted up.
Work great. I'd recommend leaving your windows up for 24hrs after the install to set the glue. The window holds the visor tight against the door and will keep the glue on the tape firm against the door to set it.
I've had mine since the summer and zero issues so far.
Old 01-25-2016, 03:02 PM   #7
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
In-channel with tape/glue? That's interesting. Seems to defeat the purpose of them being in-channel.
Don't the WeatherTech in-channel visors just pop in?
Old 01-25-2016, 03:08 PM   #8
It was my first time using window visors so I had nothing to compare them to. They have a thin strip of double sided tape on the front side of the in chanel part. When the window is up, it pushes against the visor pressing the tape against the door.
I couldn't imagine it without the tape. When the window is down nothing would be holding the visor to the door. I guess it just gives extra security and also stops any chatter it could make when the window is down and you're on the highway.
Old 01-26-2016, 08:46 AM   #9
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
I have AVS in channel visors I bought from Scott a while back. I received them second hand and do in fact have double sided tape from the factory. I cleaned the old tape off and applied new tape.
Also, be sure to clean the inside track really good with a microfiber towel and some good cleaning solution then let it air dry and then do a final surface prep with alcohol.
I love mine, I think they look great but it took me a little while to get used to them since it makes the window frame about twice as thick and takes some time to get adjusted to the amount of side window glass you have to look out of.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 01-26-2016, 11:16 AM   #10
Thirty-Nine
Do you have pics of them on your car? Trying to get an idea of how far they protrude out from the windows.
Old 01-26-2016, 12:06 PM   #11
In comparison to ones I've seen on Honda's where I live they do not protrude too far, maybe 2-2.5" from the top. The pic WeeYari posted gives you a good idea.
Some of the one's I've seen on cars around here look plain silly. They're massive and they are over channel so they just look goofy and not factory at all
Old 01-26-2016, 01:56 PM   #12
The AVS profile appears to be quite similar to my Toyota visors. Basically, they sit proud of the window enough to slip your fingers in under the edge. So maybe 1/2 to 5/8th inch. My car is not handy to me at the moment so I cannot actually measure the cap between window and visor.
Left Channel coming out Both Speakers suddenly MedMantle In Car Entertainment + Electronics (audio / video / alarm) 5 11-28-2015 07:43 AM
FS/FT: Eclipse 3650 4 + 1 channel amp yaris2010RS Items for Sale by private party 3 03-11-2011 11:24 AM
Issue for LP setting on 4 channel amp. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 02-08-2010 12:10 PM
bridging 4 channel amp o2cavyss In Car Entertainment + Electronics (audio / video / alarm) 20 01-21-2010 03:40 PM
Stick On or In Channel Visors schreck General Yaris / Vitz Discussion 20 04-22-2009 06:27 PM
