Old 01-24-2016, 10:45 AM   #1
atlantatan1
atlantatan1's Avatar
Drives: 2015 Toyota Yaris
wider Tires
I have 2015 Yaris 3 doors with following tire size P175/65R15. I would like to have wider tires installed, can I go with 195/65R/15 or what other size,thanks for any information.
atlantatan1 is offline   Reply With Quote
Old 01-24-2016, 12:22 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
195/60/15's fit nicely on stock wheels and suspension.
Old 01-24-2016, 02:20 PM   #3
Keep in mind that the /65 in the tire size is the sidewall height as a ratio to the tire width. Increase the width of the tire and you need to downsize the sidewall ratio. A 195/65R15 will therefor be a taller tire than the 175/65R15 and would throw off the accuracy both your speedometer and odometer.
Old 01-24-2016, 06:10 PM   #4
atlantatan1
Thanks I'll go with that
Old 01-31-2016, 01:54 AM   #5
rabbito
rabbito's Avatar
mine came as 185/65/15 stock...going for 195/50/15 a little bit wider but reduced side walls..
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-18-2016, 04:31 PM   #6
MUSKOKA800
MUSKOKA800's Avatar
195/55-15 are very close to stock size. A bit shorter but as close as you can get to
my originals which were 185/60-15. I also had 175/65/14 steeles with winter boots and a set of 215/35-18 on TRD wheels (pictured to the left).
Old 02-18-2016, 05:15 PM   #7
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Here is a link to my favorite tire size calculator. It compares the original size to a selected new size and gives you the differences, and how it will affect the speedo. I use it all the time at work.
Tire Size Calc
brushforhire is offline   Reply With Quote
Old 02-19-2016, 02:57 AM   #8
toad
toad's Avatar
Drives: street-legal go-kart
i have 195/60/15 on my 07 and it works well. something you might want to think about is the price as different sizes i noticed while shopping for new tires can be more expensive than others(ie the 195/55 was more than either 195/60 or 195/50).
toad is offline   Reply With Quote
Old 02-19-2016, 01:54 PM   #9
jcboy
Drives: Sedan 07
not to mention that 175/65 r15 is already more than 3% bigger in diameter than the 175/65 r14 our cars were intended to have (either that or the r14s are 3% smaller )
in any case, they are right, the right upgrade for wider tires would then 195/55 r15. but 195/60 r15 is not bad, but is a larger tire, and ideally good for your highway mileage, but bad for your stop-and-go city mileage due to rotational inertia. (your car will be higher, but the fender gap will also be less.)
Existing stock tires on a wider rim, any Fuel Efficiency cons? hondaconvert Fuel Economy Forum 3 09-06-2012 12:47 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
