Old 01-26-2016, 12:18 PM   #1
GED9000
Drives: 2007 Toyota Yaris
Wiper Sync Issue
Having trouble finding a good source to troubleshoot a problem I recently begun having. Hopefully I can explain it correctly.
The driver side wiper blade of my 2007 Yaris is out of sync with the other wiper. First thing that usually happens is my passenger side wiper blade engages before the drivers side, so that when the driver side engages it ends up running into the bottom of the passenger side wiper and will not complete its cycle leaving most of the driver side windshield untouched.
I have manually pulled up the driver side wiper but if I do that it eventually ends up getting stuck on the left side of the car and won't return to the resting position unless i force it down. This basically means past a few cycles the drivers side windshield wiper is unusable.
Was hoping someone here could shine some light on this problem before I bring it to the shop and hopefully give me an easy fix.
Thank you for your assistance.
GED9000 is offline   Reply With Quote
Old 01-26-2016, 03:49 PM   #2
the wipers are both moves uniformly via a single motor. Therefor if you are having syncing issues is likely that one of your wiper arms was installed at a different orientation.
All you'd have to do is pop off the black tab where the arm attaches to the car and use a socket to remove the arm. Then reinstall in proper orientation
Driver Side Wiper Issue justfillingtime DIY / Maintenance / Service 2 02-15-2013 08:08 AM
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
front wiper issue 2009BBPliftback General Yaris / Vitz Discussion 1 12-17-2009 08:16 AM
windshield wiper issue whiteghetto DIY / Maintenance / Service 7 02-15-2009 05:22 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
