Old 01-28-2016, 05:35 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Baffled by annoying Squeaking Sound
I've had this since last year. I first thought it was the sway bar bushings, or suspension, but they are all fine. I changed two motor mounts that were bad and though they might be the problem, and I'm still getting this issue.
It happens when you put the car in D or shift into R. The transmission shifts fine. I replaced the transmission fluid with full synthetic WS compatible last spring at 50k. The sound usually stays there and comes back and goes. Sometimes you hear it over bumps or when you accelerate
xdarkxfirex is offline   Reply With Quote
Old 02-01-2016, 07:26 AM   #2
dobbiedoo
Dobbiedoo
dobbiedoo's Avatar
Drives: 2009 5 door Hb Yaris
Squeaking sound
Could be coming from the springs, mine creak a lot.
dobbiedoo is offline   Reply With Quote
Old 02-01-2016, 11:07 AM   #3
check the exhaust connection at the header. Sometimes the spring bolts will squeak.
Old 02-01-2016, 03:26 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
Probably that. When the vehicle is cold and hasn't been run for a while: leave it in Park with ebrake off, have someone rock the vehicle forwards/backwards. This will flex the engine on it's mounts and cause that joint to flex (and probably squeak).
Cheers.
Old 02-01-2016, 10:32 PM   #5
andulong
andulong's Avatar
Drives: 2008 Hatch Red
The Hamster might be getting hungry! Sorry, I couldn't resist.
andulong is offline   Reply With Quote
Old 02-02-2016, 04:11 PM   #6
bairjo
I hear that same sound coming from the apartment upstairs...and yes I hear more when they seem to accelerate.
coolant, mounts, transmission
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 03:14 AM
Finally found the answer to the annoying ticking/rattling sound from inside... YarisSedan General Yaris / Vitz Discussion 2 05-10-2012 06:39 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
Squeaking Sound underneath 2008 Toyota Yaris Sedan Automatic SDYarisGuy DIY / Maintenance / Service 3 02-27-2011 06:36 AM
That annoying ding sound! GRRRRR! KnytewolF General Yaris / Vitz Discussion 4 01-13-2009 02:25 AM
