Old 02-04-2016, 02:20 PM   #1
ViosBelta
Drives: Vios 2009
RANDOM ELECTRONICS RESET
Hi all! I'm from the philippines and i own a 2009 vios which is the same as the yaris sedan. My car's electronics will randomly reset cluster light and gauges blinks then dies , radio shuts off, power steering doesnt work, headlight/fog light/indoor light flickers this happens in a couple of seconds the everything will work again with the exception of the power steering which needs another start up to make it work. This happens usually at night when i have the lights on. Battery is OK. Alternator is OK... The only thing i notice is i don't have passing lights(when my HL is off, i have Hi/Low Beam when it is ON) and my speedo doesnt go down to 0 it just stays at between 5-10kph when idle.
Scanner detected the codes:
C0200 :
front current speed sensor RH Circuit
C0205: Front current spped sensor LH Circuit
ABS/VSC NOT OK
MAIN BODY NOT OK
are any of these codes related to the issues i have? If not what could be the problem?
Thank you, YARIS WORLD.
ViosBelta is offline   Reply With Quote
Old 02-04-2016, 06:51 PM   #2
Those codes are all likely due to the loss of power while running. Check for corroded battery terminals or corroded connectors where the large wires snap into the back of the positive battery terminal.
Old 02-04-2016, 11:35 PM   #3
ViosBelta
Drives: Vios 2009
I just had a quick check on the terminals it looks good to me. I will still yet to look on the connectors. Are you refering to the white and black that snap on the back?
Old 02-05-2016, 06:18 AM   #4
ViosBelta
Drives: Vios 2009
Just checked the both the terminal, the black and white socket wires. They look good to me., no corrotion. I'm uploading photos now, maybe i missed something. Could you take a look at it later? @CTScott
Edit: link to pictures
https://www.dropbox.com/sh/fcs2d2i59...q-eSH86Ga?dl=0
Old 02-05-2016, 08:05 PM   #5
They don't look bad at all. Have you done any modifications to the electrical system (new stereo, aftermarket headlights, etc.)?
Old 02-05-2016, 08:46 PM   #6
CT_CJ
Drives: 2010 Base
Has the ever even seen flooding/water?
CT_CJ is offline   Reply With Quote
Old 02-06-2016, 02:27 PM   #7
ViosBelta
Drives: Vios 2009
My stereo is a touchscreen OEM HU and also my horns are the Bosch Europa Supertones.. that's all the mod i've got
Old 02-06-2016, 02:27 PM   #8
ViosBelta
Drives: Vios 2009
No it is not flooded..
Old 02-06-2016, 03:18 PM   #9
Since it only happens when the headlights on, check all wiring to the headlights.
Also check all of the connectors in the under-hood fuse box to make sure one is not loose.
And, check all of the ground straps between the battery and chassis and engine and chassis.
Old 02-09-2016, 04:38 AM   #10
ViosBelta
Drives: Vios 2009
Okay, so i haven't experienced the problem for the last 70kms. I've Been driving from home to work with my lights on day/night. Maybe there was a loose connection somewhere in the circuitry. Although the speedo does not go down to 0(maybe a sensor problem) . Thank you for the help
Old 06-24-2016, 09:26 AM   #11
ViosBelta
Drives: Vios 2009
I need to bump the thread. It happened again, this time on plain daylight...
Old 06-24-2016, 07:18 PM   #12
jra
Drives: 2015 yaris L
Something like that can be hard to track down. Check all the grounds you can find, could be a relay going bad, but I don't think one relay would control that many things. Maybe the ignition switch?
jra is offline   Reply With Quote
Old 07-07-2016, 11:55 AM   #13
ViosBelta
Drives: Vios 2009
Finally found the problem, the wirings on the negative terminal to the body and starter was loose. Had to cut and resolder. that explains also why i had trouble starting the car.
-problem fixed-
Old 07-07-2016, 11:58 AM   #14
ViosBelta
Drives: Vios 2009
Thanks man
Old 07-07-2016, 12:13 PM   #15
ViosBelta
Drives: Vios 2009
Didn't notice it was broken until i tried bending the cable and the wires popped out.
Engine runs fine after ECU reset, poorly shorty after Zachccccc DIY / Maintenance / Service 30 01-21-2016 09:41 AM
Needs some help with a very random random misfire Echo02 DIY / Maintenance / Service 8 03-28-2013 10:28 PM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
Reset ECU ? packetrace Cosmetic Modifications (Exterior/Interior) 6 09-01-2011 05:27 PM
Random feature Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 7 12-17-2006 05:24 PM
