Old 02-08-2016, 10:33 AM   #1
Tinkerman
Drives: Yaris 5 speed
Joust bought one
Just bought a 2 dr hatchback 5-spd.
It's red! But not much choices here.
Needs new tires, the damn things is bald :(
It has 65K miles.
I'm going to give it an over all inspection of everything.
I plan to replace the followings:
Plugs. What kind should I get?
Brakes, all around. Where is a good place to buy parts online?
Fuel filter
air filter
fresh air filter
Tires. I thinking to buy some aluminum rims with it. Where is a good place to buy tires and rims other than Tirerack?
What else should I replace? Thanks guys.
Go Yaris!
Tinkerman is offline   Reply With Quote
Old 02-08-2016, 11:05 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
discounttiredirect.com is a great place for wheels and tyres... and they are having a huge sale beginning today!
Old 02-09-2016, 12:08 AM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Just go with something like a K&N drop in or else an OEM one for air filter.
Fuel filter is part of the in-tank fuel pump assembly and rarely is changed.
Spark plugs shouldn't need to be changed at 65k, but if you feel the need go with NGK Iridiums.
Might want to look into the cabin filter DIY. Your lungs and sinuses will thank you. The DIY is much cheaper than OEM.
Toyotapartszone.com for the OEM brakes. They are cheapest, but a little slow on shipping.
Look at the lighting stickied thread for thinking about upgrading to LED in cabin bulbs.
Is it a manual or auto? If manual change the transmission oil to a quality synthetic of 75-90.
Verify whether or not the few safety recalls have been completed with your local dealer. Be prepared to provide your VIN.
Sent from m-o-b-i-l-e
Old 02-09-2016, 04:08 AM   #4
rabbito
rabbito's Avatar
every fluid and filter inside the engine..oil, air filter (K&N), cabin filter, transmission fluid(i did it anyways..), brake fluid while changing brake pads (it wasnt worn out but did it anyways), flush radiator (end of 2nd year owning the car), tires (it wasnt worn but did it anyways)..
this is what i did on begining of 40k
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-09-2016, 08:15 AM   #5
Tinkerman
Thank you for the tips. Didn't know the fuel filter is part of the fuel pump.
Old 02-09-2016, 08:17 AM   #6
Tinkerman
Good points changing brake fluid and flush coolant.
Thank you.
Old 02-09-2016, 08:18 AM   #7
Tinkerman
Thanks, I'll take a look.
Bought a Yaris happywanderer New YARIS Purchase Forum 5 05-15-2011 05:23 PM
Just bought 2010 yaris with 42 miles Drama New YARIS Purchase Forum 6 12-21-2010 08:35 AM
Bought a loaded Yaris!!!! Yariswhite09 General Yaris / Vitz Discussion 7 08-30-2009 09:36 AM
Just bought our 2nd Yaris Auto sedan in 20 months MauiDan New YARIS Purchase Forum 11 04-08-2009 02:53 PM
Bought lots from Sparks Toyota... drdavidr4u Cosmetic Modifications (Exterior/Interior) 4 11-21-2006 12:10 PM
