Old 02-09-2016, 04:44 PM   #1
Tylervanpool
Drives: 2013 Toyota Yaris
Alternator Wiring Harness
Hello,
My battery light is showing on my dash indicator and the Toyota dealership is saying that their test came back showing that I have no charging amperage coming from my alternator to my battery. My alternator is stock but brand new. I personally think there is a problem with voltage going to the alternator through the alternator harness and not telling the alternator to turn on or to charge the battery. Could someone please tell me what each of the 4 wires does that are leading into the harness? I want to test each one with a micrometer but don't want to go probing around on wires I don't need to mess with. I think there is a Yellow/black stripe, black, green, and a blue.
Tylervanpool is offline   Reply With Quote
Old 02-09-2016, 05:37 PM   #2
nortonfb
Drives: 2007
Check the horn fuse under the hood, that will throw the battery symbol.
nortonfb is offline   Reply With Quote
Old 02-09-2016, 07:53 PM   #3
What you talkin bout Willis?
On the 4 pin alternator connector:
White: Feedback via the ALT-S fuse (check that fuse)
Green: Ignition switched power (via the 10A Gauge fuse - check that too)
Blue: Charging indicator output (should be +12 volts with alt running)
Pink: Output to AC and ECM to let them know alt is working
Also, check the two large fusible links built into the positive battery terminal. It is easy to short the wire from the battery to the alternator when changing the alternator and doing so will pop one of these.
Old 02-11-2016, 02:10 PM   #4
Tylervanpool
Alternator light
I checked the fuses and they look good. The wiring harness itself looks bad from the car. Looking somewhere to buy a replacement
ECU Extension Harness??? KTS Performance Modifications 13 06-26-2014 10:03 AM
For Sale: AEM F/IC (FIC) 30-1910 with Boomslang Harness $400 CTScott Items for Sale by private party 5 12-03-2013 06:07 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 10:42 AM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 04:19 AM
