Old 02-16-2016, 09:26 AM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Crap getting in around the MAF sensor
Every time it gets cold my car starts throwing CELs about it running rich if I let it idle too long. It's done that since going to the 1zz injectors. I've just not worried about it for the last few years. This year it did the same thing, then the CEL just stayed on. I finally pulled the codes this morning and noticed the P0101 MAF code. I've fought the friggin' MAF in this car many, many times. I guess the little rubber/foam seal thing around it's gone a bit janky, as crap is able to get in there between the MAF and the plastic snout. Those sensors cost way too much for what they are and I really don't want to buy another one. Can I put silicone gasket sealer around it and be fine?
Old 02-16-2016, 09:40 AM   #2
don't they have an O-ring on them?
Old 02-16-2016, 09:41 AM   #3
can you make adjustments to your tune?
Old 02-16-2016, 09:49 AM   #4
47_MasoN_47
You might could call it an o-ring. It feels more like a piece of foam or something.
I could adjust my tune if I ever installed that F/IC I bought like 3 years ago, lol.
Old 02-16-2016, 10:02 AM   #5
47_MasoN_47
Found the part number for the O-ring. Didn't really think about being able to buy that separately. I'll try this first before doing anything else.
For reference - MAF O-ring part number is 9009914141
Old 02-16-2016, 10:05 AM   #6
Cool. When you get around to installing it, make sure to lube it with some silicone spray or paste. It'll really help it avoid taring and help seal it.
Yaris '99 MAF sensor location. MrNinety DIY / Maintenance / Service 0 11-04-2014 10:12 AM
WTS Jet Power Flow MAF Sensor yangjiesheng Items for Sale by private party 2 06-13-2013 02:29 PM
High Performance MAF Sensor fnkngrv Forced Induction Forum 3 02-25-2012 08:05 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
