Old 03-04-2016, 02:22 PM   #1
klej89
Flashing dash when engine is OFF
Hi,
I have a Toyota Yaris II 2011 that has problem with flashing dash (speed-,tachometer pointer and high coolant temperatur indicator) when engine is OFF.
https://onedrive.live.com/?cid=7E8AA...%21103&o=OneUp
Sorry for poor English.
klej89 is offline   Reply With Quote
Old 03-04-2016, 08:24 PM   #2
Wow! That is strange. The items flashing are controlled by the microcontroller of the cluster, so it may be an internal problem with it. Check the two connectors to make sure they are plugged in tightly, just in case.
Old 03-05-2016, 04:39 PM   #3
klej89
I checked this two connectors (16 and 24 pin) - all look fine. Indicator and pointers stop flashing when I pulled out and put on again after a few minutes the 7,5 Amp fuse ECU-B (some sort of reset?). Unfortunately, after a few days the problem returns... After starting the engine, everything looks good, indicator and rest do not flashing.
Old 03-05-2016, 09:59 PM   #4
The ECU-B fuse feeds constant power to various ECUs, including the cluster's microcontroller, so that makes sense that pulling it would temporarily clear the issue.
Old 03-20-2016, 03:01 PM   #5
klej89
I found the solution to my problem.
On pin 1, black wire, plug right (power supply of meter after ignition) appeared voltage when the engine was turned off.
12 V when the plug was pulled out.
8-7 V when the plug is connected.
Unfortunately, the power scheme does not agree with the "2007 Yaris Factory Repair Manual", probably because I have a start-stop system.
I cut off the old wire and connected to pin 1 new wire supplied directly from the IG2 relay (15A fuse AM2). For now everything looks good.
Old 03-20-2016, 07:32 PM   #6
Pin 1 should be ignition switched power, even on your European Yaris with start/stop. With that wire having some power on it when the car is powered off, I would be concerned about something dragging the battery down, when it should not be drawing current.
Do you have any aftermarket electrical system modifications?
Old 03-21-2016, 02:55 PM   #7
klej89
I do not have any modifications of the electrical system.
I know that on this pin should not be voltage with the engine off.
I have three basic problems:
1) On the back of the Instrument Panel J/B I have three sockets
In the schematic in the "2007 Yaris Factory Repair Manual" There are four sockets ...
2) I checked for continuity from pin 4 sockets 4F (Front Instrument Panel J/B) to pin 1 of a plug meter (MET 7.5A fuse was inserted) - there is no continuity (according to the scheme should be).
3) I can not remove the instrument panel because I can not unscrew the two bolts from the passenger air bag. For this reason, I do not have good access to Instrument Panel J/B and all the cables.
For these three reasons, at the moment I made a new wire to the power meter.
p2138 engine code crazylegs DIY / Maintenance / Service 25 08-20-2020 05:40 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
