Old 03-21-2016, 12:45 PM   #1
BCbenny
Adding Air Conditioning to 07 yaris
I have a base model 07 sedan yaris. I enquired with toyota about six months ago about an a/c kit (the dealer in victoria B.C.) which they were showing a part number for at the time. I didn't get it when I called but now they are saying it's not available. I have the ability to install a kit and could probably scour around to make my own but it's so much easier to just buy a kit so does anybody have any online sources which may still be able to provide a complete installation kit? Or maybe they can still get a kit for an 08 that might work for an 07? Anyone with any info is helpful (unless the info is something along the lines of "save yourself 1000$ and roll your windows down..." my wife wants a/c, she'll get a/c)
BCbenny is offline   Reply With Quote
Old 03-21-2016, 01:01 PM   #2
I don't know the part # for the kit (I don't even know if there is one) however I'd call some junkyards and see if you can find a scrapped Yaris for the parts. It would save quite a bit of money
Old 03-21-2016, 06:45 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
they do have one , i was going to do the same on my CE hb and last time i looked it was on sale ..old stock at Toyota Canada , around $680 for a full kit that is down from 900+
but im to cheap so Mexican air it is for now ...or maybe a new Yaris we just got the two tone white black in.
Old 03-22-2016, 12:01 AM   #4
BCbenny
680$ isn't horrible where did you see that and when did you look? thanks for the tip.
Old 03-22-2016, 12:21 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Toyota cost , my price since i work at Toyota and it was in the annual sale section they do all the time.
Old 03-23-2016, 11:25 PM   #6
BCbenny
Hmm so how would I go about getting that same kit here in B.C. seeing as they don't seem to be able to get it here? You'd think if they had it there in ontario that they could get it here too.
Old 03-24-2016, 12:17 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
If Toyota BC cant find it then i dont think Toyota Canada has it , last time i looked was about a yr ago.
Old 04-05-2016, 07:12 AM   #8
cparker
Drives: 2014 Yaris L
AC alternative , 12 volt swamp cooler.
There's an outfit down in Mesa Az. that sells 12 volt plug in swamp coolers, designed for use in a vehicle. As long as Victoria BC has mostly dry summers like Oregon, they work great. Prices start around $400.00 for their smallest model. Might be able to find one on Ebay for less. That's less than having AC installed in your car. You can also use it in your house with a converter. I worked as a delivery driver and the van didn't have AC ,This made a big difference . If this link doesn't work, Google swampy.net. http://www.swampy.net
cparker is offline   Reply With Quote
DIY: Adding AUX input to 2006 french Yaris - W58824 sven337 DIY / Maintenance / Service 4 04-17-2022 12:59 PM
Air Filter for 1.4 Diesel SR 2008 Yaris wrenaudrey DIY / Maintenance / Service 0 11-09-2014 02:22 PM
Will the US version Air Box of the yaris fit in mine? kustomrtr DIY / Maintenance / Service 0 07-24-2014 04:45 PM
