Old 03-24-2016, 01:44 AM   #1
komichal
Headlight tilting problem
Hi folks,
my Yaris 2007 had an accident and multiple front right parts had to be replaced... complete headlight included.
Now I have my Yaris back and after some time I have noticed that the headlight tilting (hopefully this is the right name for moving the headlight up and down with the small circular control from the cockpit to adjust the beam height) works strange.
- The RIGHT side that was destroyed and replaced works fine
- The LEFT side headlight that was safely intact is almost not moving, only in one moment the parabola moves a bit (but to the opposite direction then the RIGHT side)
What puzzles me is that the wiring for the right and left tilt motor is not matching - the colors are in a different order. Check out the picture... Obviously the RIGHT stuff was replaced completely but actually it works, it is the original LEFT stuff that seem to have problems.
When I take the LEFT tilt motor out I can see that the motor stick is smoothly going in and out so it seems that I need to change the complete headlight?
Thank you for all your comments...
2013 Toyota Yaris headlight problem Tgawe DIY / Maintenance / Service 15 11-07-2014 10:52 AM
Problem with my car rakhan01 DIY / Maintenance / Service 8 12-03-2010 05:12 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 06:51 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
