Old 03-29-2016, 09:14 PM   #1
Arcadia
Drives: 2008 Hatchback
Pink gunk eminating from Engine Hose
When I was cleaning the battery terminals on my 2008 Hatchback I noticed that a pinkish/purple fluid had crusted over on a cable that leads out from the engine. Can someone help me identify what cable this is and what might be going on?
Thanks!
Arcadia is offline   Reply With Quote
Old 03-29-2016, 09:48 PM   #2
That's not a cable - It is a coolant hose going to the throttle body (used to heat the air entering the throttle body). Coolant is the pink fluid that is leaking.
Old 03-29-2016, 09:55 PM   #3
Arcadia
Thanks CTScott. Should I be concerned about this or just clean it up?
Old 03-29-2016, 10:14 PM   #4
I would replace the hose or at least check it and replace the clamp.
Old 03-30-2016, 07:38 AM   #5
I had the same last year. Coolant hose clamp on the throttle body had failed.
Old 03-30-2016, 10:09 PM   #6
CoryM
Drives: 2009 5-door, 5-speed
On that hose it is likely just a weak clamp. However, it is also possible for the hose to be leaking. It should be fixed as it may prevent the engine from sucking coolant from the reservoir (and it can pop off or burst if bad enough).
Old 11-22-2016, 08:03 PM   #7
Arcadia
Do you know the part number for the hose? i searched but am unable to find it.
Old 11-22-2016, 11:16 PM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
16264 HOSE, WATER BY-PASS, NO.2
16264-21070
16264A CLAMP OR CLIP(FOR WATER BY-PASS HOSE NO.2)
90467-13054
crusty, engine, hose, pink, purple
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
