Old 05-12-2007, 08:12 PM   #1
Centurion2200
Centurion2200's Avatar
Drives: Yaris Hatchback 07
Send a message via MSN to Centurion2200
Can the 2NZ-FE use the same performance parts than 1NZ-FE?
Hi,
My Yaris HB is 1.3 but it has the 2NZ-FE engine, it looks exactly the same as the 1NZ-FE, the difference is only on the internal cc......
For example, can i use the megan header?.... intakes, pulleys...... bolt-ons in general.....
thanks
Centurion2200 is offline   Reply With Quote
Old 05-12-2007, 08:20 PM   #2
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Best way to find out about manifolds is to head down to your local parts store and see if they'll let you look at a 1NZ and 2NZ gasket side to side.
Same/similar gasket = same bolt pattern.
Intakes are a little easier as they are mostly chassis dependent. As long as the 2NZ TB is in the same place as the 1NZ's your fine.
WRBlue is offline   Reply With Quote
Old 05-12-2007, 10:02 PM   #3
ChinoCharles
Drives: LB
Crank pulleys for the 1NZ fit the 2NZ. That is all I know.
Old 05-13-2007, 03:38 AM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Intake won't. Is in a totally different position.
Old 05-13-2007, 03:02 PM   #5
nigel
Drives: yaris
crank pulley yes, iam using it on my 1300cc 07hb
nigel is offline   Reply With Quote
Old 05-14-2007, 01:05 PM   #6
Centurion2200
The intake on the 2NZ and the 1NZ is exactly in the same position.....
The 2NZ-FE isn't the same 1.3 engine from United States.....
I found in some parts websites that the exhaust gaskets are the same for both NZ's......
And the big question....... TURBO???....the zpi will work?
Old 05-14-2007, 03:36 PM   #7
CASTREX
CASTREX's Avatar
Dude, i'm not from the states. I'm just a little bit north from you.
and btw I have 2 Yarisss 2007 in my garage. A LB 1.3 2NZ and a Sedan 1.5 1NZ
So I will like to see you fit a 1.5L intake on a 1.3L
Well... at least that your are talking about the 1NZ on the old echo wich I think has a different intake position.
Old 05-14-2007, 03:42 PM   #8
CASTREX
CASTREX's Avatar
This is the intake on the 1NZ.
Do you have a picture of the 2NZ engine bay?
I don't think the turbo kit will fit on your car... (as a bolt on) at least the piping. You will also have to do a new tune for the emanage.
Old 05-14-2007, 04:06 PM   #9
ZPIracing
ZPIracing's Avatar
Drives: Scions
Post a pic of the engine bay. Toyota typically keeps this stuff the same so i would think it will fit with minimal mods. Not sure about the ecu the wiring would be a little different but i think the tune would be close.
Thanks.
ZPIracing is offline   Reply With Quote
Old 05-14-2007, 04:12 PM   #10
Centurion2200
it looks exactly the same as the pic above..... i'll post some pics as soon i get home....
Yaris here in panama have the same engine that the echos....
Old 05-14-2007, 04:38 PM   #11
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
On old echo/yaris/vitz they were on the same position, do not know about the new one though since it has change a bunch from the 1st generation
echo/yaris/vitz .
Good luck with your find Centurion
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 05-14-2007, 05:15 PM   #12
weaponrcamry
Drives: Camry LE/Yaris Hatch 5spd
Im pretty sure that the intake wont fit. Unless you custom make the tube, and you will have to make a MAF adapter their are different as well as the sensors.Yea toyota usually make things compatible without to much difficulty. The only reason why alot of things are the same because of their engine codes. For example
5s-3s
2jz-1jz
1MZ-3MZ
7M, 5M etc.
And the same with honda, most of their parts are compatible.
Since the yaris uses the NZ design, I would most likely say they will wit with minimal modification.
|.....Overnight.........................| ||
|........Parts From Japan.............||'|";,__
|_..._...____________======||_|_|....,,]
weaponrcamry is offline   Reply With Quote
Old 05-26-2007, 09:01 AM   #13
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Yeap, you can use a lot of them.
thoughts for yaris parts turboyaris Performance Modifications 55 06-18-2007 08:40 PM
C-ONE Performance Parts "IN STOCK" KamiSpeed Sponsors Classifieds Area 19 01-11-2007 05:26 AM
Quick Questions about general performance parts. wlfpck Performance Modifications 3 11-16-2006 10:58 PM
Performance parts yariman Performance Modifications 22 07-25-2006 08:27 PM
Performance parts yariman Performance Modifications 5 03-22-2006 04:52 PM
