Old 04-08-2016, 06:54 AM   #1
Pinchlite
Drives: 2007 yaris HB
Speaker spacers.(2007 HB)
I am going to put 6.5 speakers into my front doors (2007 HB)I came across these and was wondering if they would work with the yaris.The price seems fair from what I have seen.This is canadian denomination btw.Thanks for any and all help.
https://www.amazon.ca/uxcell%C2%AE-B...CE359D6HZ8KW0P
Pinchlite is offline   Reply With Quote
Old 04-08-2016, 08:59 AM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
I am not sure about those, they look close, but I couldn't find any real info in the net.
It seems like Amazon's canadian site really doesn't list a whole lot of options for mounting rings.
Have you considered buying speakers from crutchfield.ca? They include free mounting brackets, wire harness adapter, vehicle specific install instructions. You can usually get a much better speaker, than at best buy for the same money, including all install gear.
Here is a quick link to some nice kenwood speakers: Speakers.
brushforhire is offline   Reply With Quote
Old 04-08-2016, 09:43 AM   #3
Pinchlite
I have looked there but dont see any mention of brackets included.I can also get same model speakers cheaper elsewhere.
Old 04-08-2016, 10:23 AM   #4
brushforhire
When you add them to your cart, they let you pick rear or front install gear.
Keep us updated on what you end up doing.
Old 04-08-2016, 10:26 AM   #5
On the crutchfield site, once you add an item to your shopping cart, they also itemize the items they include for free. In the case of speakers, the items are:
Wiring Harness - retail value $22.99 CAD
Mounting Brackets - retail value $29.99 CAD
The speakers I have were ordered from crutchfield. Yes I did get brackets, but I still had to drill new holes in the door as the mounting screw locations did not line up.
Old 04-08-2016, 11:15 AM   #6
Pinchlite
That seems like a good deal.I wont need a wiring harness but the brackets will be needed.Thanks for the infos.
Old 04-08-2016, 11:48 AM   #7
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
You will need the wires with adapter plugs, as the connectors on the Toyota harness aren't standard.
I shopped around for a good deal on speakers, then bought the mouting rings and adapter wires on eBay. That saved some money, although less convenient than buying the whole kit together from Crutchfield.
Sent from my LG-D801 using Tapatalk
Old 04-08-2016, 12:10 PM   #8
Pinchlite
I will look into it further.I havent even removed the stock speaker yet.I prefer to solder and shrinktube my connections.Thanks for the reply.
Old 04-08-2016, 12:48 PM   #9
^ get and use a harness!
2012 Audio Upgrade FAQ and Build Log muffin_top In Car Entertainment + Electronics (audio / video / alarm) 19 01-19-2022 06:28 PM
Front and rear speaker installation pics LugNut In Car Entertainment + Electronics (audio / video / alarm) 14 08-31-2015 02:49 PM
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
Speaker Rattling kylemhall In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:24 AM
2009 4dr. LB Speaker Wiring Question AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 4 05-09-2010 09:48 PM
