Old 04-12-2016, 10:49 AM   #1
Redflow2014
Redflow2014's Avatar
Drives: Yaris d4d
Door lock problem
Hello
I have a 2004 Yaris d4d.
Recently the drivers door won't lock while using the remote locking or the button on the door from inside. Sometimes it unlocks with the remote. Mostly now it just won't work. I have to use the key which still unlocks and locks all doors.
I have no idea how to even try and get the panel off to have a look I tried and almost broke something.
Help please.
Thanks.
Redflow2014 is offline   Reply With Quote
Old 04-12-2016, 12:06 PM   #2
Kar98
Drives: 2011 Scion tC
Different model year, but it can't be that much different:
http://www.yarisworld.com/forums/showthread.php?t=2305
And this is what I found underneath, explaining why one side didn't lock/unlock anymore:
http://www.yarisworld.com/forums/showthread.php?t=56182
Old 04-12-2016, 12:18 PM   #3
ercdvs
Drives: 2010 Yaris
Also I have the same issue on a 2010 yaris. My research pointed to a faulty lock actuator on that side.
Pull the door panels, and you can either get away with cleaning contacts, etc, or just replace the unit
http://www.yarisworld.com/forums/showthread.php?t=44694
ercdvs is offline   Reply With Quote
Old 04-12-2016, 01:09 PM   #4
Redflow2014
Drives: Yaris d4d
How do I get the actual lock actuator out now I removed the panel?
Old 04-12-2016, 03:06 PM   #5
My rear passenger door has the same problem.
Q. If you cycle the door lock back and forth does it eventually work?
mine works, but only after a few tries. If I'm locking the car, I make sure to hit the lock button, either on the door, or the remote a few times to make sure the all the door actually lock.
If, you're having trouble, it might be best to replace it. I think the striker/latch and power actuator are all one unit.
Old 04-12-2016, 03:10 PM   #6
Pretty sure you have to remove the large bolts from the outside of the door around the latching mechanism and anything inside the door attached to it.
Old 04-12-2016, 03:18 PM   #7
ercdvs
Drives: 2010 Yaris
there are a few videos showing this for different toyota models, and damn its involved.
I havent actually found a model to replace the actual motor itself with, but the entire actuator unit is around on amazon, ebay, etc.
The motors should be fairly generic, but you need specs
EDIT: research has shown the motor you need is more then likely this:
http://www.amazon.com/Central-Actuat.../dp/B00BYD0QVK
Old 04-12-2016, 03:37 PM   #8
Redflow2014
Drives: Yaris d4d
It's very difficult t remove. I undone everything I could see attached to it and it's still being held in place by something. Looks like I'll have to take it in to the garage
acceleration problem yaris 2012 sedan ahmedmhb Middle East 1 10-17-2013 04:32 AM
Help: dealer might not be able to fix window problem (2012 Yaris) matti Third Gen Yaris General Discussion 5 01-31-2013 10:37 PM
Car Race/IDLE/initial speed Problem mamun22s DIY / Maintenance / Service 0 08-28-2012 06:29 AM
Problem with electronic door lock new-yaris-owner In Car Entertainment + Electronics (audio / video / alarm) 7 08-05-2012 05:12 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
