Old 04-14-2016, 03:52 PM   #1
mik23
Drives: yaris 2005
Hissing Noise
Hi All
I am listening a strange hissing noise from driver side inside car. it only happen when I am driving on speed.
can anyone help;.
mik23 is offline   Reply With Quote
Old 04-14-2016, 11:52 PM   #2
bairjo
Don't drive while on speed. Drugs are bad for you.
Old 05-01-2016, 05:09 PM   #3
robkay
Drives: Hatch
Maybe you are scaring your snake.
robkay is offline   Reply With Quote
Old 05-02-2016, 04:01 PM   #4
mik23
Drives: yaris 2005
Thts no solution chaps
Sent from my GT-I9195 using Tapatalk
Old 05-03-2016, 11:27 AM   #5
robkay
Drives: Hatch
I guess the question draws out the humor in some of us.
This is kind of a tough one. Some cars have vacuum hoses under the dash. Did you investigate under the dash? Maybe a loose vacuum hose? Any sign or odor of coolant? Have you tried various settings of the air flow control?
Are you certain it is inside the car? Sometimes tires can make strange noises on certain pavement at certain speeds. Is your tire wear even?
You might need to take it to a dealer and have someone ride with you and listen to it.
Old 05-03-2016, 11:56 AM   #6
If it's only at speed then it's likely not a vacuum issue but more of a tire or wind issue. Use a diagnostic reader to check fuel trims and what not. This will rule out anything somewhat serious.
Old 05-03-2016, 10:52 PM   #7
bairjo
Post a video. ..that may help more than words alone.
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
Colour Collection 05 Reg (UK) brake noise JLx DIY / Maintenance / Service 0 07-14-2015 06:56 AM
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 12:20 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
