Old 04-19-2016, 06:33 AM   #1
Pinchlite
Drives: 2007 yaris HB
newer tires in the rear
My used Yaris came with 2 different brands(summers)the new ones are uniroyal and in excellent shape with little wear.
The other ones are weather max with more wear but within safe spec.
These tires are also different tread pattern
I think I will put the newer better treaded tires(same brand) in the back.I have read this is better.
(No matter if your vehicle is front-, rear-, or all-wheel-drive, a pickup, a sporty car, or an SUV: If you buy only two new tires, you should put them on the back, according to tire manufacturer Michelin North America)
Pinchlite is offline   Reply With Quote
Old 04-19-2016, 11:57 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
That's the normal recommendation. I believe the idea is that any loss of traction will be more noticeable on the older tires. This means you car will tend to understeer or run wide, in turns. Most people can correct this more easily by easing off the throttle and /or applying more steering lock.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 04-20-2016, 06:02 PM   #3
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I always put the new pair on the front as that's where maximum wear is. Once they're run in, which will happen quite soon on the front, then it's all pretty much the same.
Sent from my LG-D801 using Tapatalk
Old 04-20-2016, 06:44 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Like tarkus, I would have assumed you want the most traction on the wheels doing the most work.
Learn something new everyday, eh?
Old 04-21-2016, 12:20 AM   #5
tarkus
tarkus's Avatar
Brand new tires will have slightly less traction until they're worn-in a bit. that will happen pretty quickly on the front.
Old 04-21-2016, 05:16 AM   #6
bronsin
bronsin's Avatar
I learned the hard way new tiresome on a curve on a snowy road. go on the rear when I went into a spin at 15 mph
New tires do NOT GO ON THE FRONT,
Old 04-21-2016, 01:50 PM   #7
tarkus
tarkus's Avatar
With ice and snow there's no predictability what can happen, whatever your new /old tyre configuration. Living in Canada, I should know! :-)
Old 04-21-2016, 04:51 PM   #8
bronsin
bronsin's Avatar
Try this:
When the roads are snowy but plowed, put a set of worn tires on the rear wheels with newer ones on the front. Pick a deserted road with a curve and take the curve at 5 10 15 20 25 mph until you skid out (spin) now change the tires front to back and try it again.
You ll fine you can take the curve faster with the worn tires on the front and the newer ones on the rear.
Old 04-21-2016, 07:13 PM   #9
LeeS17
Drives: Yaris 08 Hatch - No equip
Try this:
But you will have more understearing and longer breaking distance
LeeS17 is offline   Reply With Quote
Old 04-21-2016, 07:51 PM   #10
bronsin
bronsin's Avatar
Try it and choose. The loss of control is pretty dramatic.
Old 04-21-2016, 07:55 PM   #11
Pinchlite
Thanks to you and everyone that replied.I have the best tires on the back.I will be buying 2 new next summer and those will go on the back.
The tires that are on the back know are pretty near new as it is so it should work out good when I rotate with the new ones next year>
Old 04-21-2016, 08:15 PM   #12
tarkus
tarkus's Avatar
Try this:
If they're that worn, I wouldn't have them on either the front or rear in winter time. I always use snow tyres with lots of tread, whether new or used.
I have also been fitting new winter tyres on the front as long as I can remember, always installed a couple of weeks or so before the snow season starts, so that they're worn-in by the time the snow driving starts. Never had any problems with that at all here in Toronto.
Old 04-22-2016, 08:49 AM   #13
bronsin
bronsin's Avatar
I think if you rotate the more worn tires to the rear for summer and then back to the front for winter you'd be OK.
This would presume that you drive conservatively. If you drive aggressively I think you're going to experience this problem sooner and even on roads that are just wet.
Old 04-23-2016, 12:03 AM   #14
kimona
kimona's Avatar
Drives: 2014 White VITZ
This from the discounttiredirect website:
http://www.discounttiredirect.com/di...ireMounting.do
Old 04-23-2016, 12:21 AM   #15
tarkus
tarkus's Avatar
OK we appear to be talking about different levels of wear. If a ťyre is worn to the point there's a significantly increased risk of aquaplaning, then it shouldn't be used at all, and needs to be changed - period. It's not worth the risk.
Old 04-23-2016, 12:09 PM   #16
bronsin
bronsin's Avatar
This of course is pretty crazy since of fwd cars rear tires wear much faster on the front. Maybe twice as fast.
I put the new tires on front for 40 years until I has an accident...
Old 04-24-2016, 01:47 AM   #17
kimona
kimona's Avatar
On Monday, I'll be moving the rear tyres to the front and installing new rubber on the rear.
Old 04-24-2016, 02:27 AM   #18
tarkus
tarkus's Avatar
After a hundred or two miles of wear, it will become a moot point which is at the front or the back.
Use of a can of tire sealant voided road hazard warranty nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 02-22-2014 07:49 PM
Max Wheel Width on Factory 175/65R15 Tire? Lerico Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-18-2013 02:02 PM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Winter tire width Ironphil Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-21-2009 01:47 AM
