Old 04-24-2016, 02:06 PM   #1
Jappa
Toyotaholic
Drives: Toyota Yaris XP13 (French)
Changing luggage light
Hello,
I am new to this forum, and i am from the Netherlands!
I want to change the luggage light to a LED bulb, but i cant find how i can change this light.
Can someone tell me how i will get it lose?
Sorry for the bad english sometime`s.
Jappa is offline   Reply With Quote
Old 04-24-2016, 10:26 PM   #2
YarTed
Drives: 2015 Yaris 5Dr
Yar Engels is goed, I mean your English is good .
Sorry I don't have your answer. Welcome to the forum, hopefully someone will be able to help
YarTed is offline   Reply With Quote
Old 04-25-2016, 03:47 AM   #3
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
I fitted a l.e.d. lamp to my luggage space/boot/trunk light. 2014, French built.
It is very easy.
The plastic cover has to be removed. You should be able to see where to lever it off. Use a small screwdriver with the blade wrapped with some electrical tape or similar.
It's a double ended/festoon lamp. Like this https://www.amazon.co.uk/Can-bus-Fes...festoon+lights . I can't remember the length so you will need to check before ordering though.
Edit to add, these are the ones I bought in March 2015. https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 . The one I fitted is still working fine and the other is a spare.
I also fitted these to my interior/ceiling light last April. https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
The plastic cover is removed in a simialr way to the boot lamp cover but mine was a tight fit, so care is needed not to break or crack the cover!
mrpj is offline   Reply With Quote
Old 04-25-2016, 03:12 PM   #4
Jappa
Toyotaholic
@YarTed Thank you!!
@mrpj Thank you for your help. I`m going to try it tomorrow!
Old 04-25-2016, 10:14 PM   #5
YarTed
Your very welcome Jappa, hope the light works out for you
Old 05-27-2016, 06:52 AM   #6
Jappa
Toyotaholic
I stil dont got time to measure the light bulb.
Does anybody now wich size bulb i need for the luggage light and the dome lights behind the sun visors?
Are this the right ones or does this not fit?
http://www.autoledplaza.nl/7744759/9...mm-kleur--rood
Luggage room light not working docbuster Suggestions - Feedback - Questions 0 01-02-2016 04:51 PM
changing cv joints and speedometer and brake light off ntokozo General Yaris / Vitz Discussion 6 09-29-2015 06:00 PM
2007 yaris hatch back 3rd brake light (stop light) MegaMatt DIY / Maintenance / Service 12 06-15-2015 10:55 AM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
Changing the tail light vincentg DIY / Maintenance / Service 3 04-04-2012 08:07 PM
