Old 04-27-2016, 09:55 AM   #1
2007yariz
Drives: Yaris sedan
Exclamation anyone tried 5w40 or 0w40 in the 1.5 Litter Yaris
hello,
I know the Yaris calls for 5w30 motor oil, but I have some 5w40 and 0w40 laying around, I wonder if it is ok to use it in the U.S. Yaris? Anyone tried it?
2007yariz is offline   Reply With Quote
Old 04-27-2016, 10:49 AM   #2
I use 0w30 year round to help in the winter start ups. I have an oil temp and pressure gauge and have noticed no decreases in oil presure that would be concerning.
IMO 5w40 and 0w40 is fine to use. I'm thinking about running 5w40 in the summer and ow30 in the winter. Problem is our summers are relatively short and I don't want to change oil every couple months. Plus, I have no issues with pressure or temp running ow30 in the middle of summer
Old 05-05-2016, 02:38 AM   #3
B.B._07
Drives: 07 5dr
It shouldn't hurt but 5W40 and 0W40 are but more designed to be used in diesel engines and can also be used in gasoline engines. 5W40 is very close to the factory recommended 5W30, with only the warm viscosity being somewhat higher.
Old 05-05-2016, 10:51 PM   #4
bairjo
Go ahead and use it if you want to void any warranty you may have left.
Old 05-06-2016, 07:57 AM   #5
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Really? Who's going to know?
Sent from my LG-D801 using Tapatalk
Old 05-06-2016, 12:07 PM   #6
bairjo
It will show up on the receipt you provide as proof the oil change was actually done.
Old 05-06-2016, 01:04 PM   #7
tarkus
tarkus's Avatar
Maybe....
Old 05-09-2016, 04:14 AM   #8
rabbito
rabbito's Avatar
so many different oil that was left from the oil change in the past..i mixed them all together and did an oil change..no problem so far 1000km+ and oil still look fresh af
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Yaris 1.5 Turbo OEM Amplexus PL General Yaris / Vitz Discussion 0 03-16-2013 01:38 PM
yaris ts 1.5 turbo Paris vvt-i Forced Induction Forum 31 03-14-2012 08:05 PM
GT28 OK for 1.5 Yaris engine? riverc4c Forced Induction Forum 12 10-20-2010 06:07 PM
