Old 04-27-2016, 09:13 PM   #1
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
looking for 2007 vitz part number
I have the rear disc axle on my 2006 yaris, now the rubber boot is damaged and the lower slider pin is also giving problems, I don't think it was the correct slider pin when I first got the axle. I added grease but the pin has chips like it was stuck before and was forced out with wrench or screw driver.
Anyways does anyone have or could get the toyota part number for those items? Also is there another toyota in canada or usa that uses the same parts instead of ordering from Japan. Thanks.
Adriaan is offline   Reply With Quote
Old 04-28-2016, 07:40 AM   #2
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Have you tried parts from a 2015/2016 hatchback SE? I know they come with rear disk brake axles, so you might have some luck in finding them in Canada, rather than having them shipped from Japan?
Old 04-28-2016, 08:58 AM   #3
Adriaan
In between cities
Adriaan's Avatar
I'll try a 2016 yaris for the rubber boot, I know the top pins aren't the same. There the same as the corolla xrs, but the bottom isn't the same.
Old 04-28-2016, 10:31 AM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
i have the same issue as you regarding the slider pin fro the caliper! My pins fit just fine, and i shaved a little bit off to make it work..but i ordered pins for a 09 corolla xrs rear caliper since they also share the same brake pad, and same sized disc. Sorry, it's still sitting in a bag. I need to get rear discs for a '12+ yaris SE to replace first, to go along with my TOM's pads.
Help finding part number joell DIY / Maintenance / Service 19 01-06-2015 02:41 PM
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 12:25 PM
NGK spark plug part number?? Jerkratt Forced Induction Forum 16 03-27-2012 07:06 PM
Does anyone know the part number for OEM rally style spoiler? caineroad General Yaris / Vitz Discussion 1 08-19-2009 12:31 AM
So there is no part number for the LED tail light? caineroad General Yaris / Vitz Discussion 3 08-17-2009 08:09 PM
