Old 05-01-2016, 07:36 AM   #1
mik23
Drives: yaris 2005
Clunk noise on a bump when on speed
Hi All,
I am experincing a confusion here
On a road with 8 - 9 bumps on single bump i hear a clunk noise from rear of the car. I am unable to figure it out where it is. Car is running fine and no funny noises on other roads. I like to mention this particular road is on steep hill with loads of bump I am sure not many to standard construction.
But noise is from rear side
Can the experts help here where to look what
Yaris 2005 99k
cheers
mik23 is offline   Reply With Quote
Old 05-01-2016, 09:49 AM   #2
make sure your shocks aren't wet looking indicating they're leaking. Then look for loose parts.
Old 05-01-2016, 02:33 PM   #3
Check to make sure the mounting bolt on bottom of rear shock is tight. I once had a loose one that on visual inspection appeared tight but was loose enough to creating clunking noises over bumps.
Old 05-02-2016, 04:02 PM   #4
mik23
Drives: yaris 2005
Which one can u pls advise
Sent from my GT-I9195 using Tapatalk
Old 05-02-2016, 04:10 PM   #5
This one.
Old 05-02-2016, 04:26 PM   #6
mik23
Drives: yaris 2005
Thanks I will check tihs weekend what size they are 12?
Old 05-15-2016, 10:06 AM   #7
mik23
Drives: yaris 2005
Nothing found but i noticed on a certain hump i got clunk from any car at speed >25m
Old 05-15-2016, 10:07 AM   #8
mik23
Drives: yaris 2005
If less than 19m than its all ok
Old 05-22-2016, 10:13 AM   #9
mik23
Drives: yaris 2005
Thanks I lube it and tight all four.
No funny sounds now.
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 305 10-27-2025 01:52 PM
Yaris sales hit new low... Kal-El Third Gen Yaris General Discussion 131 10-18-2025 11:59 AM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Irritating Door Noise Anakha56 Third Gen Yaris General Discussion 1 04-21-2013 11:06 PM
Noise from rear of Yaris APS67 DIY / Maintenance / Service 5 09-25-2011 06:51 AM
