Old 05-02-2016, 09:02 PM   #1
alnen
Drives: 14 Yaris
Oil pressure light normal at start up?
My wife just informed me that her 14 Yaris has a "little c next to a boat" light that comes on every morning for a few seconds at start up. I assume this is an oil pressure light, and would venture to guess that it's normal to see first thing in the morning. I want to double check with you guys before I dismiss it. Thanks.
alnen is offline   Reply With Quote
Old 05-02-2016, 09:33 PM   #2
Yes. That is normal.
Old 05-02-2016, 10:42 PM   #3
BLKHILLSGUY
Drives: 2011 3dr LB Polar White
Normal. But that is the cold engine light, not the oil pressure light. Two separate lights. Put it in accessory mode so you know the difference between the two lights. The blue light disappears once the engine reaches optimal temperature. Basically, I don't floor it until the light has shut off.
BLKHILLSGUY is offline   Reply With Quote
tire pressure light Lorenzo1950 DIY / Maintenance / Service 4 08-23-2010 10:20 PM
tire pressure light goes on and off, on and off janices_yaris DIY / Maintenance / Service 8 07-30-2010 03:58 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
Are these oil pressure readings within range? LtNoogie Performance Modifications 14 03-21-2009 12:35 AM
