Old 05-05-2016, 04:23 PM   #1
EricGSXR
EricGSXR's Avatar
Drives: Yaris NSP90 1.33 TTE
Windscreen washer
Good evening all,
My '14 Yaris Hybrid is spraying windscreenfluid all over the place, except on the windscreen. It's spraying too high, and too far away.
The nozzle is installed on the wiper blade arm and I've tried to adjust it with a needle. The nozzle isn't adjustable.
Any tips?
EricGSXR is offline   Reply With Quote
Old 05-05-2016, 04:37 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
I have a 2014 Yaris as well. That BIG wiper was the first surprise, then I discovered that the squirter was located on the wiper!
So, I can't simply squirt the windscreen as I had with my 2007 Yaris. I've learned to squirt when the wiper is operating and in a vertical position; otherwise, the fluid completely misses the glass... and even squirts someone on the sidewalk as I drive by.
Old 05-05-2016, 05:01 PM   #3
EricGSXR
EricGSXR's Avatar
Exactly, that's the same problem I have.
Old 05-06-2016, 05:15 AM   #4
Justhandguns
Drives: Yaris Icon 1.33
Well, it looks like it is designed to squirt at cyclists and pedestrians. The only way is to hold it down until you wiper is in upright position in order to cover the entire windscreen.
Justhandguns is offline   Reply With Quote
Old 05-07-2016, 07:45 AM   #5
EricGSXR
EricGSXR's Avatar
This problem will be solved this month :)
I've ordered a wiper arm nozzle:
Old 05-07-2016, 06:09 PM   #6
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
Originally Posted by EricGSXR View Post
Good evening all,
Any tips?
Looks like its typically for MK3 after facelift. Friend of mine, who has '15 Yaris Hybrid have that problem. There is no issue with mine Mk3 '12 Yaris
karloslatynos is offline   Reply With Quote
Old 05-08-2016, 07:54 AM   #7
bronsin
bronsin's Avatar
Ford had this system in the 80s as I recall...
Then there was my 74 Bug with a one pint washer tank pressurized with a hose from the spare tire. You mmight get 30 short squirts before empty and refill was a chore.
"Hmmm the windshield needs cleaning....should I use the washer?....I havnt done it in a month....yes by gosh Im going to do it!....what the hell life is short....here she goes!....WOOO HOOOO!"
Windscreen washer fluid tank volume? dj92 DIY / Maintenance / Service 0 10-16-2013 04:29 PM
Windscreen washer jets dodsy General Yaris / Vitz Discussion 2 06-04-2011 01:04 PM
Removing Windshield Washer AGlobalThreat Fuel Economy Forum 14 05-02-2011 07:27 PM
Windshield Washer Indicator captainm27 General Yaris / Vitz Discussion 25 01-21-2009 07:26 PM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
