Old 05-13-2007, 11:29 PM   #1
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Firewall Acess
Real soon am I going to add a cool subwoofer (ala spkrman) and really only hate one part of the job, and that is coming through the firewall. If anyone has a chance to snap a pic of where they came through I would really appreciate it!
blacksan is offline   Reply With Quote
Old 05-14-2007, 08:47 AM   #2
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
I have Fog Lights sitting in a box for 2 months now... I have the same problem... I am scared of that damn Firewall!
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 05-14-2007, 09:28 AM   #3
Nutzoids
Nutzoids's Avatar
Echo... Are you talking about this thing?????
Old 05-14-2007, 09:35 AM   #4
blacksan
blacksan's Avatar
Originally Posted by echo_hrs View Post
I ran mine through the rubber grommet where all the factory wires go through. It has extra channels (holes) you can poke through to run the wire watertight...
Sorry no pics, but it's near the top of the firewall behind the battery...
Cheers
Oh, I didn't even notice that! If I pull the dash apart can I see where this bundle enters the cabin?
Old 05-14-2007, 09:38 AM   #5
blacksan
blacksan's Avatar
Cheers
If you pull the battery can you get a better look at it?
Old 05-14-2007, 07:45 PM   #6
Nutzoids
Nutzoids's Avatar
Alright, Well I saw it... and I was able to get to it... But there is no way, Without taking apart my Front Strut and Battery I can get to it, to do anything!
This is a much bigger job then I first thought... Weekend Job!
Old 05-14-2007, 08:02 PM   #7
blacksan
blacksan's Avatar
He said nipples.
Old 05-14-2007, 10:22 PM   #8
blacksan
blacksan's Avatar
ECU
I crawled up under the dash this evening and it looks like unbolting the Main Body ECU would bring the wire conduit in to even better prospective. When I pulled the tiny compartment door out at my left knee (seated position) it was a pretty clear shot to the conduit
echo_hrs, what did you remove?
Old 05-15-2007, 02:56 AM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
There is a rubber grommet just above the ECU mounted on the fire wall. It's super easy to get to from the inside and outside.
Old 05-15-2007, 07:15 AM   #10
blacksan
blacksan's Avatar
[QUOTE=PetersRedYaris;85856]There is a rubber grommet just above the ECU mounted on the fire wall. It's super easy to get to from the inside and outside.[/QUOTE
Which ECU? Snap a pic from the exterior when you get a chance.
Old 05-15-2007, 08:18 AM   #11
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
i just ran my power wire through the grommet where the heater hoses run inside the car. those hoses run so close to many wires under the dash that i see so there is no chance of melting anything especially a high gauge wire for an amp very protected
d2dailly is offline   Reply With Quote
Old 05-15-2007, 09:50 AM   #12
blacksan
blacksan's Avatar
Didn't remove anything. Taped my wire to a coat hanger and fished it through one of the "nipples" on the inside into the engine bay behind the battery...
PS your schematic is the sedan...
Cheers
Cool, I know the schematic is a sedan, but the ECU is in the same location.
Old 08-23-2007, 04:02 AM   #13
EggMan
EggMan's Avatar
Drives: 2007 Yaris liftback
This thread brought back some painful memories. Good luck.
EggMan is offline   Reply With Quote
Old 09-09-2007, 09:54 PM   #14
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
I saw that square tube Nutzoids took pics of but under the steering wheel it's almost no sight of the other side of it. im not even sure if you can access it on a sedan even after u remove the battery it's actually on the right of the battery. im going to remove my battery anyways just incase i find another way i can go thru w/o having to create a new whole and waterproofing it or w/o removing too many parts
so far, using a coat hanger seems to be the way as long as i can get to this grommet with nipples.
manborn is offline   Reply With Quote
DIY: Groundwire Kit ItsMyDaily DIY / Maintenance / Service 149 09-06-2010 01:59 AM
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 03:04 PM
Firewall!! plushDJ In Car Entertainment + Electronics (audio / video / alarm) 7 06-01-2006 12:20 AM
